3.08 crashes
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
jan kudelasek
octane 3.08.1 180612 194737.log
(83.96 KiB) Downloaded 252 times
3.08+ seems to be very unstable for me. I´m working with bigger scenes (8,5G), . A lot of crashes when try open Material Editor, etc. during rendering. In 3.07 everything goes well. I´m using displacement and and normal maps from megascans. I´m posting error log. I have already increased TDR to 60 sec, but not help. W10, 3ds max 2014, 64 GB, GTX 1080 Ti, driver 398.11.
Thank you
Jan
W7 / Quad Core Xeon E5405 / 24G / Asus ENGTX 480, 580 / http://www.allcity.cz / https://www.facebook.com/pages/Allcity/ ... e=bookmark
paride4331
Hi jan kudelasek,
You could try with Nvidia drivers 391.35.
To get an effective Nvidia drivers installed, you could use DDU Nvidia unistaller drivers, the best way to get a clean installation.
http://www.guru3d.com/files-details/dis ... nload.html
Regards
Paride
jan kudelasek
Hi Paride,
thank you for your advice. I have tried it but not helped. :/
Any other other idea?
Thank you
Jan
paride4331
jan kudelasek,
did you update your sistem using Windows Creators Update before you had this crashes?
Regards
Paride
jan kudelasek
paride4331 wrote:jan kudelasek,
Regards
Paride
yes, I did, before I install 3.08. When I run 3.07 now, everything is ok.
I have some troubles with updates, after instalation, my screen shut down and Pc is not restarted.
Jan
paride4331
Regards
Paride
Jan
Hi jan kudelasek,
what about your motherboard?
Asus x99?
could you test my unistaller worflow and Nvidia 388.13
Regards
Paride
jan kudelasek
Hi Paride,
my mother board is MSI X299 SLI PLUS. I have tried your uninstall workflow, installed driver 388.01 but not helped :/. Are you sure that problem is on my side?
Jan
jan kudelasek
Could you reproduce this issue? Or I can send you my scene. I´m very frustrated, I have to switch back to 3.07.
Thank you
Jan
paride4331
Hi jan kudelasek,
If you want I could test your issue, but this is a well-known issue with update, usually 10 Fall Creators Update, x99, x299 and Cuda drivers.
It does not depend on Octane and also affects other render engines.
This issue is also discussed on the web in many forums, many users are waiting for a solution.
Windows 7 has not issues, very solid and stable.
Regards
Paride
jan kudelasek
paride4331 wrote:Hi jan kudelasek,
Regards
Paride
Ok, thank you for clarify me the porblem. Do you know about some method how fix the problem?
Regards
Jan
Return to “Bug Reports”
