3.08+ seems to be very unstable for me. I´m working with bigger scenes (8,5G), . A lot of crashes when try open Material Editor, etc. during rendering. In 3.07 everything goes well. I´m using displacement and and normal maps from megascans. I´m posting error log. I have already increased TDR to 60 sec, but not help. W10, 3ds max 2014, 64 GB, GTX 1080 Ti, driver 398.11.
Thank you
Jan
3.08 crashes
C. RAM Capacity (i.e. 6 GB)
- jan kudelasek
- Contact:
W7 / Quad Core Xeon E5405 / 24G / Asus ENGTX 480, 580 / http://www.allcity.cz / https://www.facebook.com/pages/Allcity/ ... e=bookmark
- paride4331
Hi jan kudelasek,
You could try with Nvidia drivers 391.35.
To get an effective Nvidia drivers installed, you could use DDU Nvidia unistaller drivers, the best way to get a clean installation.
http://www.guru3d.com/files-details/dis ... nload.html
- jan kudelasek
- Contact:
Hi Paride,
thank you for your advice. I have tried it but not helped. :/
Any other other idea?
Thank you
Jan
Thank you
Jan
- paride4331
jan kudelasek,
did you update your sistem using Windows Creators Update before you had this crashes?
- jan kudelasek
- Contact:
yes, I did, before I install 3.08. When I run 3.07 now, everything is ok.paride4331 wrote:jan kudelasek,
I have some troubles with updates, after instalation, my screen shut down and Pc is not restarted.
Jan
- paride4331
Hi jan kudelasek,jan kudelasek wrote:yes, I did, before I install 3.08. When I run 3.07 now, everything is ok.paride4331 wrote:jan kudelasek,
Jan
what about your motherboard?
Asus x99?
could you test my unistaller worflow and Nvidia 388.13
- jan kudelasek
- Contact:
Hi Paride,
my mother board is MSI X299 SLI PLUS. I have tried your uninstall workflow, installed driver 388.01 but not helped :/. Are you sure that problem is on my side?
Jan
Jan
- jan kudelasek
- Contact:
Could you reproduce this issue? Or I can send you my scene. I´m very frustrated, I have to switch back to 3.07.
Thank you
Jan
Thank you
Jan
- paride4331
Hi jan kudelasek,
If you want I could test your issue, but this is a well-known issue with update, usually 10 Fall Creators Update, x99, x299 and Cuda drivers.
It does not depend on Octane and also affects other render engines.
This issue is also discussed on the web in many forums, many users are waiting for a solution.
Windows 7 has not issues, very solid and stable.
- jan kudelasek
- Contact:
Ok, thank you for clarify me the porblem. Do you know about some method how fix the problem?paride4331 wrote:Hi jan kudelasek,
Jan
