Question about rayepsilon
areyal
I have a model where with default rayepsilon some faces are completely black
If I increase rayepsilon then they become right.
Can someone explain why? Which other side-effect can have increasing rayepsilon value?
GPU GTX 480 / GT 430 for UI
CPU Intel Core 2 Quad Q8300 (2.5 Ghz) / RAM 8 GB DDR2
SOFT Windows 7 64bit4
abstrax
areyal wrote:Hi,
If you have to increase the ray epsilon, your scene got exported too large.
The ray epsilon hides numerical errors, but can introduce incorrect shading and reflections, if it's too large (usually 2-3 magnitudes larger than it should be). A good rule of thumb: Try to minimize the ray epsilon as much as possible as long as you don't see artifacts. Then it's about right and there is still a lot of margin above.
Marcus
