Hi, I have file with basic materials (no textures, only with color in diffuse and different index etc.)
If I load file to Xref, object is without any materials. If I look at "XRef M" in the "XRef" there I can see materials, but in LiveViewer there is only flat model.
Thanks a lot.
XRef with no materials
I use XREFs with materials all the time. What version of Octane are you using?
CaseLabs Mercury S8 / ASUS Z10PE-D8 WS / Crucial 64GB 2133 DDR4 / 2 XEON E5-2687W v3 3.1 GHz / EVGA 1600 P2 / 2 EVGA RTX 2080Ti FTW3 Hybrid/ Cinema 4D
Is it fast? Oh, yeah!
Did you tried with default parameters of xref?
Please post your scene so we can take a look at it.
Here it is.
- Attachments
- Octane Xref.zip
- (331.14 KiB) Downloaded 195 times
I'm on R17, and when I use Create > XRef > Add XRef and load your scene, it seems to work right.
Have things changed in R19 perhaps?
OSX 10.12.4 | Intel 12 core @ 3.33 ghz | 128 gb ram | NVIDIA GeForce GTX 1080TI | Ubuntu Linux slave with 3x 1080ti
Yep, I was suspicious when I saw the screen cap you posted, Mibu . You've used the legacy Xref, as opposed to the current system. If you follow the steps outlined by nietsudio, you should be good to go.
