Camera Projection Mapping/Alphas Not Working
Adept
Hi! I am trying to project an alpha texture onto an object using a camera. In the viewport all works fine, however in Octane, it renders as if I had the material tag set to UV projection. How can I fix this? I have also had some issues where the entire object becomes invisible due to the alpha channel. How can I project any alpha map onto my object in Octane? (P.S., the alpha material is a diffuse mat with the alpha shader in the opacity input)
Could mind to put a sample scene here?
Adept
aoktar wrote:Could mind to put a sample scene here?
Yes, here it is :) I am trying to project the blood image onto the wall as well as the person... It works just fine on the cube and ground plane I have, but goes all wacko on the geometry of the wall and character. Thanks
Octane Projection Issue.zip
(82.26 MiB) Downloaded 224 times
You should use "world coordinate" for cameramapping with this way. see image
Adept
aoktar wrote:You should use "world coordinate" for cameramapping with this way. see image
Ahah! That fixed it completely. Thanks so much!
