Camera Projection Mapping/Alphas Not Working
Hi! I am trying to project an alpha texture onto an object using a camera. In the viewport all works fine, however in Octane, it renders as if I had the material tag set to UV projection. How can I fix this? I have also had some issues where the entire object becomes invisible due to the alpha channel. How can I project any alpha map onto my object in Octane? (P.S., the alpha material is a diffuse mat with the alpha shader in the opacity input)
Could mind to put a sample scene here?
Yes, here it isaoktar wrote:Could mind to put a sample scene here?
- Octane Projection Issue.zip
- (82.26 MiB) Downloaded 257 times
