invisible emitters reflecting in specular materials
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
Rik56
When you have a diffuse material with emitter (blackbody or texture), set the opacity of the material to 0 and enable transparent emission, you can see the reflection of the object in specular and glossy materials. The behaviour should be the same for the reflection - the object should not be visible.
Win10 64bit, cards gtx1080 + 2x gtx980ti, 64gb ram, nvidia drivers 388.31, blender octane 3.07 - 13.4, standalone 3.06.2
azen
We currently have a new version being tested internally. I will confirm whether the bug has been addressed there. Otherwise, we will seek to amend this as soon as possible.
Azen
J.C
Rik56 wrote:When you have a diffuse material with emitter (blackbody or texture), set the opacity of the material to 0 and enable transparent emission, you can see the reflection of the object in specular and glossy materials. The behaviour should be the same for the reflection - the object should not be visible.
Haven't it been discussed before?
There is an option to disable specular reflections of emissive objects – "Visible on diffuse" checkbox.
What you are referring to affects camera view of an object, not it's reflection.
System – Windows 11
aufwind
You have to uncheck "Visible on Specular" in the Emission Node Settings
Win7 | Gigabyte G1.Sniper 3 | I7 3770K | 2x Titan (Kepler) | 1x Titan X (Pascal)
Return to “Bug Reports”
