Thinner sun's size not darker! Bug?!
nuno1980
Hello!
This is bug for daylight in all versions of OR!?! Except light area - more far or thinner = darker and closer or fatter = lighter -> GOOD. Please you should fix issue for daylight in newer OR v2.2x and v3.0x.
--> PS: sunrise and sunset in OR are BADLY later and earlier, respectively, than in the real life and than in the astronomy's software (Stellarium...) too.
Urgent...
PT vs PHT kernels - spp nrs
Caustics at PT
i7-12700KF
32GB DDR4@3600
GF RTX 4090 <3 :mrgreen:
NEW ViewSonic XG2431 24" :D
mojave
Sun size in the daylight environment is in no way related to the environment power, think that if that wouldn't be the case there would be no way to adjust these independently from each other so this behavior is intended.
https://docs.otoy.com/StandaloneH/Stand ... onment.htm
nuno1980
mojave wrote:Sun size in the daylight environment is in no way related to the environment power, think that if that wouldn't be the case there would be no way to adjust these independently from each other so this behavior is intended.
Ok but I've knew about many years and very pity. :(
I decrease sun size on Daylight settings but it isn't darker because the luminosity auto-increases BADLY.
Smaller sun size doesn't decrease luminosity but the it's darker due to the sun's area reduced = sun is more far or eclipse solar occults more.
Caustics at PT
i7-12700KF
32GB DDR4@3600
nuno1980
"cleaner" - bad but yes "lighter". Sorry. ;)
Caustics at PT
i7-12700KF
32GB DDR4@3600
