I have some problem with Octane 3.06.2 and C4D R17, the live viewer and the viewport are very slow to update and move, but if I uncheck "check camera" the viewport returns to work fine.
I also have a lot of lag with the Node Editor...
Maybe it's just a problem with my computer? I'm working on iMac i7 4 GHz - OS X Sierra 10.12.5 - 2x GTX 980ti eGPU by Bizonbox
Here you can see the problem:
https://youtu.be/zIDElSuWkB4
Any solutions?
Thank you very much
Stefano
Viewport Slow
Can you post this scene?
- stefano-dear
Of course!
- Attachments
- Scene.zip
- (1.04 MiB) Downloaded 227 times
- stefano-dear
I suspect that these problems are generated by the 2 eGPUs connected via thunderbolt. Could it be?
Yes possible. Also try with "synchronisation with geo. updates=ON". But It will cause some glitches on OSX+multiview.stefano-dear wrote:I suspect that these problems are generated by the 2 eGPUs connected via thunderbolt. Could it be?
- stefano-dear
If I deactivate the "synchronisation with geo. update" the viewport it's a bit more fast!aoktar wrote:Yes possible. Also try with "synchronisation with geo. updates=ON". But It will cause some glitches on OSX+multiview.stefano-dear wrote:I suspect that these problems are generated by the 2 eGPUs connected via thunderbolt. Could it be?
- icevalleycorp
Hello,
Can i ask you wich video brand you have...? and wich bizonbox you have?
- stefano-dear
Hi,icevalleycorp wrote:Hello,
I have an iMac 27" Retina and two Bizon Box: Bizon box 1 e 2S.
- stefano-dear
Now I have seen that if I use Octane Standalone the movements and refresh are very fluid, so it should not be a problem of the eGPU.
It seems more related to the plugin or Cinema 4D.
Does anyone else have this problem?
I do as well. Seems a bit better when the live viewer is undocked, maybe. I've been playing around with Redshift and Cycles 4D and they don't show this issue nearly as much. Setting the priority level to low doesn't seem to help.stefano-dear wrote:Now I have seen that if I use Octane Standalone the movements and refresh are very fluid, so it should not be a problem of the eGPU.
iMac 4.2 GHz 40GB RAM | OS 10.13.6 C4D r20 Octane 4.02.1-R3 | Akitio Node with GTX 1080 Ti | Nvidia driver 387.10.10.10.40.122 | Cuda 410.130
Windows 10 Network Render System with Four GTX 970s, Same Octane Version
