How to fade the background to black??
dgdunne
hi guys,
I'm pretty new to Octane so here goes it.
Was wondering whats the best way to fade off geometry in the background to black? Kinda like a an environment black fog, ways away in the distance I guess...
Any and all help would be awesome! Thanks!
Hi dgdunne,
here are some ideas:
1. use the Z-depth pass to fade the far geometry with black background in post, note that the Z-depth value is in meters, and you can input the exact distance.
2. if far geometry has only one material, you can mix it with a diffuse 0 opacity, and a sineWave node in amount.
3. if you have multiple materials, you could try with this particular technique mixed with the second solution:
viewtopic.php?f=30&t=59185&p=303108&hil ... ir#p303108
Happy rendering,
