PMC crashes Octane for Maya 3.06 test 3 [ SOLVED ]
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
yfripp
When rendering with PMC kernel the render/maya freezes just before it gets to the max samples. This error occurs even in a blank new scene in both Maya 2016 SP6 and Maya 2017 update 3
All the render settings are default, just changed kernel to PMC
This is the error that appears in the output window from maya 2017:
Stack trace:
octane.dll!Octane::RenderResultStatistics::progress
octane.dll!Octane::ApiTimeSampling::operator=
KERNEL32.DLL!BaseThreadInitThunk
ntdll.dll!RtlUserThreadStart
Juri
Windows 10 | i7 4770K | Titan X | 32gb
Jolbertoquini
yfripp wrote:Hi,
Stack trace:
Juri
Actually is not support on "adaptive sampling " with PMC this is standalone thing, Use PMC without this options, Maybe Jim should hide this options when you change to PMC.
Best,
JO
Octane Render for Maya.
https://vimeo.com/jocg/videos
http://www.hmxmedia.com/
yfripp
Hi Jo,
I get the crash when Adaptive Sampling is both on and off. There is no problem rendering before hitting the max samples, if i cancel the render by pressing escape before the max samples is reached it stops as expected, it just hangs when the max samples is reached.
Juri
abstrax
I can confirm the crash is caused by Octane. It also happens in the Standalone. Will be fixed in the next release.
yfripp
Thanks Abstrax for the update.
calus
This crash have been fixed in Octane 3.06 test4 core,
so this issue is fixed in Maya since OctaneRender® for Maya® 3.06 (test 4) - 10.12
Pascal ANDRE
Return to “Bug Reports”
