When rendering with PMC kernel the render/maya freezes just before it gets to the max samples. This error occurs even in a blank new scene in both Maya 2016 SP6 and Maya 2017 update 3
All the render settings are default, just changed kernel to PMC
This is the error that appears in the output window from maya 2017:
Stack trace:
octane.dll!Octane::RenderResultStatistics::progress
octane.dll!Octane::ApiTimeSampling::operator=
KERNEL32.DLL!BaseThreadInitThunk
ntdll.dll!RtlUserThreadStart
Juri
PMC crashes Octane for Maya 3.06 test 3 [ SOLVED ]
Moderator: JimStar
C. RAM Capacity (i.e. 6 GB)
- Jolbertoquini
- Contact:
yfripp wrote:Hi,
Stack trace:
Juri
Actually is not support on "adaptive sampling " with PMC this is standalone thing, Use PMC without this options, Maybe Jim should hide this options when you change to PMC.
Best,
JO
Octane Render for Maya.
https://vimeo.com/jocg/videos
http://www.hmxmedia.com/
Hi Jo,
I get the crash when Adaptive Sampling is both on and off. There is no problem rendering before hitting the max samples, if i cancel the render by pressing escape before the max samples is reached it stops as expected, it just hangs when the max samples is reached.
Juri
Juri
Windows 10 | i7 4770K | Titan X | 32gb
I can confirm the crash is caused by Octane. It also happens in the Standalone. Will be fixed in the next release.
