Hi Aoktor and Beppe,
The new version of the c4d plug-in (3.02-R2) has stopped our Live Viewer crashing but we are still getting disconnected from our slave which is only happening with V3.
When we move the camera around the scene it is fine but the minute objects move drastically we get a disconnection from our slave in the live viewer.
I will then try and render through the picture viewer and it will just render black and count down for ever but not render anything.
I will usually then stop the render and I'll get a spinning wheel and have to force quite C4D.
Again we didn't have this disconnection problem with V2 so I don't think it's a hardware/networking issue.
Have a look through the logs and I'm hoping it's a problem you can re-create.
Thanks for your help,
Chris
V3 Live Viewer Disconnecting from Slave
C. RAM Capacity (i.e. 6 GB)
- Attachments
- Bug Report 9.08.16.zip
- (161.1 KiB) Downloaded 195 times
iMac 10.9 780M, Mac Pro 10.11 780, PC Win 10 780TI x3
I think it's the problem I just fixed: On OSX the master can run into a deadlock, i.e. no messages are sent to the slaves and no messages are received. When you shutdown C4D it will hang and you have to kill it by force, because the net render master is still hanging. The fix will be in the next release.ccpenn wrote:Hi Aoktor and Beppe,
Chris
Great thanks.niestudio wrote:So far live view with net render is working great for me in 3.03.3!
Thanks for the fix, guys
daniel
Yes been testing 3.0.3.3-R1 today and it's not disconnecting or crashing.
Thank you Abstrax, Aoktor and Beppe for all your help on this problem and the quick fix.
Regards,
Chris
Regards,
Chris
