2point - perspektive?
Jorgensen
i wonder if it's possible to do two-point perspektive (where vertical lines are all vertical) using the octane camera? (i only know this from sketchup).
i guess i can set the z-height of both camera and target to the same, but is that the way to do it?
thanks
jorgensen
mojave
There's been a discussion about this already:
viewtopic.php?f=9&t=10178
I hope it helps.
Jorgensen
ok - so the solution it to set the z-height to the same for both camera and target, and then adjust via the lens shift parameter?
i just wonder what the camera option "persp. correction" is used for then?
thanks
jorgensen
mojave
Yes, that should do the trick as well, but make sure your camera's up vector is pointing upwards.
Return to “Autodesk 3Ds Max”
