not work
3ds max 2016 SP3 win 10 2x 580 GTX
IES distribution visualisation (3.02 -4.0-4.5) not work
C. RAM Capacity (i.e. 6 GB)
- Elvissuperstar007
- Contact:
Last edited by Elvissuperstar007 on Fri Jul 08, 2016 7:02 am, edited 6 times in total.
Have you tried to turn it on?
Win 8.1 x64, i7-4930K 64GB, 2 x GTX-690
- Elvissuperstar007
- Contact:
certainly tried everything, it does not workSaramary wrote:Have you tried to turn it on?
+1 . I have a same problem with IES.
Dual Xeon E5520 2.27 GHz, 48 GB DDR III
3ds Max 2016x64, Octane render for MAX, Titan Z
The 3ds Max viewport does not refresh immediately after you enabled this feature. You need to do something in the viewport to force it to refresh after changing these settings (e.g. pan the camera). And the IES visualisation generation must be enabled if you want IES to be visualised.
But there may be still some issues, that may be caused by some particular IES files - 'cause this feature is "brand new" and not all possible variations of files were tested.
If you have issues - attach please the IES file that does not show up to the bug-report.
- Elvissuperstar007
- Contact:
JimStar wrote:The 3ds Max viewport does not refresh immediately after you enabled this feature. You need to do something in the viewport to force it to refresh after changing these settings (e.g. pan the camera). And the IES visualisation generation must be enabled if you want IES to be visualised.
- Attachments
- IES.rar
- (23.21 KiB) Downloaded 220 times
Your IES file:
Your scene:
Your scene:
- Elvissuperstar007
- Contact:
Saramary wrote:Your IES file:
Your scene:
it's not just me, I checked on 2014 sp5-2016 sp3 3ds max
loaded with different ways.
Cyrillic is not a user in Latin
I've just checked it with cyrillic IES paths - works without any problems... Have you tried different IES file paths? Is it the same for any IES paths on your machine?
It may be some less obvious reason in your case... I need some more info to guess what is happening on your site.
- Elvissuperstar007
- Contact:
user vk3d same Problem ,JimStar wrote:I've just checked it with cyrillic IES paths - works without any problems... Have you tried different IES file paths? Is it the same for any IES paths on your machine?
I tried to upload different ways
several more people checked , does not work
It may be the case in the Russian-speaking windose,
problem at all with Eastern Europe
Last edited by Elvissuperstar007 on Mon Jul 04, 2016 2:24 pm, edited 3 times in total.
