Animation rendering sequence stops at frame 1
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
clement
Hi , please find attached a c4d file + screen vid showing a problem I'm facing on a commercial project I'm working on where I need to scater flowers on a floor : I was using a mograph cloner to randomly spread instances of low poly flowers and when I tried to launch the render animation sequence , octane stops on frame 1 ( so calculate frame 0 but seems to start calculating frame 1 and suddenly stops ) . I found that the problem was one of the flowers mesh , so I isolated it to let you test . (this flower mesh was part of a commercial nature asset I bought , it's really simple and has 3 materials .. if you delete some , octane can render without stopping at frame 1 )
I tested with last R2 and R3 alpha plugin version .
thanks for checking
clément
Animation rendering problem.mp4
the screen vid to show the problem
(2.67 MiB) Downloaded 3266 times
Animation rendering problem.rar
the simple scene file
(2.56 MiB) Downloaded 275 times
Win7 x64 / Cinema4D R15.064 / I7 4930K - Nvidia gtx770
clement
here a screen of the only frame (frame 0) Octane wants to render ( sequence is arround 120 frames ) .
Thanks for great post. I'm gonna check.
I think it's because of c4d standart material with c4d shaders.
clement
Thanks Ahmet :) .
clement
seems that it's not fixed yet as I got this problem again yesterday. Any news about this Ahmet ?
I can't see any fixable stuff. You should not use c4d material/shaders as much as possible. Especially "layer". And what's the logic of "subsurface scattering" usage here? It simply crashes our "render-to-texture" engine.
Pls try to work with octane textures always. We'll have more shaders when osl version released.
clement
ha ok . well the problem I got recently didn't involve SSS c4d stuff only few simple c4d mats . But yes i removed all those c4d mat (were native in an Xref loaded character ) to make it work ;)
thanks.
Return to “Bug Reports”
