Motion vector pass - grey only
johnhill
I can't seem to get a motion vector pass out of Octane (latest version)..it simply renders a grey solid
There is definitely something wrong with motion vector in v3 alpha (not with 2.25), thanks for pointing out. I'm going to send a scene to developers that shows the issue ;)
johnhill
thanks..will wait for a fix update
microdot
I'm actually seeing an all grey MV pass in 2.25, in C4D plug-in on Mac.
No one has that issue in 2.25?
Dom Amatore
Mac Yosemite 10.10.5 | 1x GTX 980Ti |2x 2.26 8c Xeon | 24GB
Dom Amatore
www.domamatore.com
Check it scene.
mb-test.rar
(74.75 KiB) Downloaded 223 times
microdot
Thanks a lot for the reference file.
I went through and double checked compared settings, but mine is still solid grey.
Pretty sure everything is is the same. I'm just starting with octane so it's possible I missed something obvious.
I attached a file if anyone is willing to help out a noob.
New to the forum, so let me know if I need to upload differently.
Thanks again.
Dom
TEST.zip
(280.74 KiB) Downloaded 231 times
Dom Amatore
www.domamatore.com
Your values are wrong in camera tag.
Set timeshift=0 and more shutter time as 0.02, 0.04, etc..
microdot
Aha, that totally makes sense. I overlooked that after pushing those around.
Thanks a lot!
Dom Amatore
www.domamatore.com
DeePoG
Motion vectors work just fine in Live Viewer, however when I render the sequence I get solid grey only
Cinema 4d 2023, Octane 2022.1.1_R6
Untitled 3.txt
here's the project, change the extension from txt to c4d
(328.51 KiB) Downloaded 96 times
Don't know what's wrong on your scene but that's not working. But copy/paste it to a new scene and it works. Default settings are optimal on every case. See the scene.
Untitled 2.zip
(153.82 KiB) Downloaded 100 times
