Motion vector pass - grey only
There is definitely something wrong with motion vector in v3 alpha (not with 2.25), thanks for pointing out. I'm going to send a scene to developers that shows the issue
ciao beppe
ciao beppe
I'm actually seeing an all grey MV pass in 2.25, in C4D plug-in on Mac.
No one has that issue in 2.25?
Dom Amatore
Mac Yosemite 10.10.5 | 1x GTX 980Ti |2x 2.26 8c Xeon | 24GB
Dom Amatore
Dom Amatore
www.domamatore.com
www.domamatore.com
Check it scene.
- mb-test.rar
- (74.75 KiB) Downloaded 260 times
Thanks a lot for the reference file.
I went through and double checked compared settings, but mine is still solid grey.
Pretty sure everything is is the same. I'm just starting with octane so it's possible I missed something obvious.
I attached a file if anyone is willing to help out a noob.
New to the forum, so let me know if I need to upload differently.
Thanks again.
Dom
Thanks again.
Dom
- TEST.zip
- (280.74 KiB) Downloaded 258 times
Dom Amatore
www.domamatore.com
www.domamatore.com
Your values are wrong in camera tag.
Set timeshift=0 and more shutter time as 0.02, 0.04, etc..
Aha, that totally makes sense. I overlooked that after pushing those around.
Thanks a lot!
Thanks a lot!
Dom Amatore
www.domamatore.com
www.domamatore.com
Motion vectors work just fine in Live Viewer, however when I render the sequence I get solid grey only
Cinema 4d 2023, Octane 2022.1.1_R6
- Untitled 3.txt
- here's the project, change the extension from txt to c4d
- (328.51 KiB) Downloaded 123 times
Don't know what's wrong on your scene but that's not working. But copy/paste it to a new scene and it works. Default settings are optimal on every case. See the scene.
- Untitled 2.zip
- (153.82 KiB) Downloaded 140 times
