Full reload mode for DOPS
Houdini Integrated Plugin
benandaim
Was doing some DOPS stuff in Houdini and noticed the IPR wouldn't update with "FULL RELOAD" mode on (same for rendering) Just checking if this is meant to be the case or will it become something that updates like the regular transforms etc.
Ben :)
juanjgon
Can you send me a sample scene with this problem? I am testing for example a soft body DOP simulation and all seems to work fine.
benandaim
Hi Mate,
Yep you're right DOPS seems to be working, it's FLIP that's not, sorry.
Here's a scene file for you to check out.
Thanks Boss :)
flip not updating.zip
(188.66 KiB) Downloaded 479 times
juanjgon
Yes, this kind of scenes must be rendered in "full scene reload" mode, or with the "Full Reload" option enabled in the IPR. The problem is that this DOP simulation builds an object without a constant topology among the frames (variable number of points and polygons), so the mesh can't be updated and the plugin must reload it.
So to render this scene you must enable the full scene reload in the ROP or in the IPR window.
benandaim
Thanks mate,
That's what I've been having to do, just wanted to show you and check this was the correct way to do things :)
Best,
Ben.
juanjgon
Yes, currently these meshes with variable topology among the frames can't be updated. The scene must be reloaded for each frame to render the sequence.
Return to “Houdini”
