window glass - direct lighting (gi diffuse)
turtles123
hello!
i want to render a room with a big window with glass, all the light comes from the sky. only problem is that if i use direct lighting specular materials (my window) blocks all the light.
how can i make my glass to let light pass?
i would really prefer to stay with direct lighting to have less render time.
thx!!
alpha shadows. Avoid to use specular material in this kind of scenarios. Will generate lot of extra calculation. If so, make on "fake shadows". Use coherent ratio.
Also see resources in tutorials sections.
turtles123
aoktar wrote:alpha shadows. Avoid to use specular material in this kind of scenarios. Will generate lot of extra calculation. If so, make on "fake shadows". Use coherent ratio.
thx for the fast answer.
alpha shadow. "This setting allows any object with transparency (specular materials, materials with opacity settings and
alpha channels) to cast a proper shadow instead of behaving as a solid object."
this doesn't seem to help in this case.
i have played with fake shadows and coherent ratio but it doesn't help. light still doesn't pass
glossy gi diffuse.zip
(113.34 KiB) Downloaded 265 times
may be the scene file will help while i try to find something on the tutorials page...thx!
FooZe
See attached image.
Turn on alpha shadows and use the fake shadows option in the material settings.
turtles123
thx very much fooze!
i must have missed the double box to check in fake shadows inside material tab.
thx!!!
