OctaneRender® for 3ds max® v2.13
Karba
Main changes since version 2.11.1a
  • Fixed cylindrical camera mode
  • Fixed region render
  • Fixed motion blur of PF.
  • Switched to CUDA 6.5.
  • Improved performance of Maxwell 2 GPUs (GTX 970 and GTX 980).
  • Speed up processing of HDR textures which should reduce the delay when a scene with many HDR textures is loaded on the GPU.
  • Fixed displacement "cracks" (see http://render.otoy.com/forum/viewtopic.php?f=81&t=43228).
  • Fixed memory leak when environment importance sampling is used.
  • Fixed incorrect sampling when multiple GPUs with mixed render priorities are used (see http://render.otoy.com/forum/viewtopic. ... 18#p210018).
  • Fixed emitter sampling of animated meshes (see http://render.otoy.com/forum/viewtopic. ... 32#p209832).
  • Fixed mix material in the AO/wireframe info channel kernels.
  • Enabled PMC for Maxwell 2 GPUs.
  • Fixed performance regression in PMC kernel introduced with version 2.11.
  • Fixed/improved displacement mapping with negative offsets.
  • Fixed self-shadowing of objects with matte material.
  • Fixed post-processing glare.
  • Switched to a newer version of the network library used for network rendering fixing low transfer rates on some Win7 computers.
  • Fixed missing initialization of Winsock library which may cause net render daemon discovery or the daemons to fail.
  • Fixed a crash in Octane if a daemon gets enabled on the same computer as the master.
Due to the switch to CUDA 6.5 you will need a current graphics driver of version 344.x or higher.
DOWNLOAD
Installer http://render.otoy.com/plugindownloads/ ... p_2_13.zip (30MB ZIP File)
For network slave and daemon please download standalone installer here
http://render.otoy.com/forum/viewtopic.php?f=33&t=43530
Yours,
The OctaneRender® Team.
oguzbir
Good stuff. Thanks Karba. Will test tomorrow.
Edit:I test a basic PF motion blur test. Things didn't go well as expected. Will try more soon.
Could any one share your results with MB with Particle Flow?
my nvidia driver is 344.11
My Portfolio
coilbook
Thanks!
Hopefully realflow can be fixed and itoo forest motion blur
Pioner_pio
Please tell me what is better now (faster for Octane) GTX 970 4gb or GTX 780 3gb?
profbetis
Super awesome! Great work!
GTX 1080Ti 11GB (3x), Water-cooled
Intel i7-5820K 6-core @ 3.3GHz
Windows 10 Pro 64-bit, 32GB RAM
kevinshane
seems like motion vector pass is missing, also motion blur duration not working, and motion blur steps not working~~please look into that~thanks
MSI GT70 laptop i7-3610QM+32G+GTX680M 4G
Octane Arch/Interior Viz Tutorials
http://www.kshane.com
bicket
Thank you Karba
I hope we could have a render passes selector inside octane viewport.
PortFolio
4 x TITAN - Win 7 64 - Octane Rocks
oguzbir
Here is my report regarding motion blur.(MB)
MB steps, MB duration, MB checkbox, does not update until you move the time slider.
If I try MB with Particle flow. (Tested with geometry with particle flow box object shape and shape instance a teapot)
MB I think works but the samples are stuck 1 and oct. viewport repeat the first sample only with loop.
(tested using one and multi gpu's)
IF partcile flow elements like;
PF Source 001
PF Source 001 -> PF Source 001
PF Source 001 -> Event 001
Are set at object motion blur. Blur doesnt work.
Vertex motion blur works in some cases but only with final render. not octane viewport.
There is a lot of possibilities to test but all I can say atthemoment is that.
It doesnt work properly.
Karba here is a basic test scene an max 2014 format.
testMB_max2014.rar
(19.93 KiB) Downloaded 351 times
My Portfolio
kevinshane
test with realflow abc file motion blur , still no any motion blur for the fluid(deform object)! but the shark did produce some motion blur(static object with no deform)...those ojects both are abc format! Should I send this test scene to you Mr.Karba??It's about 400MB~~
Philipp1980
Hey everyone,
as soon as I install the v2.13, nothing is rendering anymore. Not in the material libraries and not in the render viewport. When opening the material editor, 3ds max crashes. As soon as I go back to the previous version it works again. Is there anyone else with this problem?
Greetings :)
