TEST: 2 boxes with fog
nuno1980
Hi!
Screenshot - PMC setting with 10k-reject, caustic blur 0.01 and parallelism 1:
box fog on left - appear good caustics and box fog on right - insufficient caustics
If the bit ball for laser is inside the box fog then appear easily caustics:
If the bit ball for laser is outside the box fog then appear very hardly caustics.
Therefore, I think the PMC kernel has the bad optimization...
PT vs PHT kernels - spp nrs
Caustics at PT
i7-12700KF
32GB DDR4@3600
GF RTX 4090 <3 :mrgreen:
NEW ACER Predator XB273U F5 27" :D
nuno1980
@FooZe: Are you investigating this issue?
Caustics at PT
i7-12700KF
32GB DDR4@3600
nuno1980
Is this issue hard??
Caustics at PT
i7-12700KF
32GB DDR4@3600
nuno1980
NOTICE!!
@FooZe, @admin or @moderator: Do NOT delay to you respond me!!
Caustics at PT
i7-12700KF
32GB DDR4@3600
glimpse
don't see anything 'bug' like except Your incompetence with render engine, Sorry for straight forward answer.
What You're trying to achieve, Nuno? You want to split the light & see the rainbow spectrum in the fog? =)
my rig is on the road, but I'll give a look into this, 'cos You're messing with this case way too long..
Please, post REFERENCE image of what You want to get.
nuno1980
glimpse wrote:don't see anything 'bug' like except Your incompetence with render engine, Sorry for straight forward answer.
About rainbow - I did never enable the dispersion for fog. - But it used for?
Reference image - for example:
Caustics at PT
i7-12700KF
32GB DDR4@3600
Daniel
I think you need to at least understand the basic physics behind these phenomena before trying to tackle these effects.
First of all, the image you posted looks to be light coming from a projector, so the source of the light is multicoloured, it's not being split by another medium. Secondly, fog is nowhere near dense enough a material to split light. It has to travel through something like glass or diamond, and at an angle no less, if you want to see the spectrum of light come out the other end.
Core i7 950 @3.07GHz | GTX 460 2GB | 12GB RAM | Window 7 x64
nuno1980
Daniel wrote:I think you need to at least understand the basic physics behind these phenomena before trying to tackle these effects.
Ok. :) The light source (laser) multicoloured isn't needed but yes it's a example. The disperison is for prism or diamond only. ;)
How do I fix my issue? Newer version of OR?
Caustics at PT
i7-12700KF
32GB DDR4@3600
nuno1980
Please you respond me!
Caustics at PT
i7-12700KF
32GB DDR4@3600
nuno1980
Do NOT delay to reply!!!!! :? :? :?
Caustics at PT
i7-12700KF
32GB DDR4@3600
