I may be doing something wrong, but I suspect this is a bug.
Ever since installing version 2.06 / 0.12.142, I have trouble modifying Octane materials
Examples:
When I change opacity of glass material, then hit reload in the render viewport, the opacity resets to the prior value. This seems to happen with every parameter, so in effect I cannot edit materials.
Mapping of materials is screwy. It doesn't match the dimensions I specify in the SU texture. It seems to be off by a factor of 8x - 10x
Once a SU material is linked to an Octane mat I can't change from a bitmap in the diffuse to an rgb color.
Often, the Octane material parameter popup appears but is unpopulated. Then when/if it eventually appears, it is corrupted and all the buttons lock up or do strange things.
Anyway - I need to know if I'm doing something wrong, or if there is a patch, or if there is a previous version I should roll back to for now.
Can't edit materials
- jscottsmith
(2) Geforce GTX780-6GB | i7 5820/6800 | 32GB
Win 10-64 | Octane v3.05.3 | NVidia v381.65
Scott Smith
J. Scott Smith Visual Designs, Inc
https://jscottsmith.com/
Scott Smith
Apart from random buggy empty material menu (solved with exit of group edit., and sometimes the need to restart SU) i dont report almost any crash.fuzzybro wrote:Hello jscottsmith,
Could you please provide the scene where this issues happened?
I tried to reproduce them without success.. everything seems to work fine.
Fuzzy
Materials sometimes unlink, but can't find a reason/step to explain what i did. But 95% of times no problems
Cheers
Resmas
i7-2600k | SSD Vertex 3 | WD Velociraptor | WS Revolution | 16GB Ram HyperX | PSU LEPA G1600W | 3 X Asus GTX590 |
https://pt-pt.facebook.com/arq.resmas
fuzzybro wrote:Ah come on, post some scenes or provide scenarios! Let's make it 100%
For now i upload the result. of a 95% working plugin
Cheers
Resmas
