Can't edit materials
Forums: Can't edit materials
Postby jscottsmith » Mon Sep 29, 2014 2:50 am
jscottsmith Mon Sep 29, 2014 2:50 am
I may be doing something wrong, but I suspect this is a bug.
Ever since installing version 2.06 / 0.12.142, I have trouble modifying Octane materials
Examples:
When I change opacity of glass material, then hit reload in the render viewport, the opacity resets to the prior value. This seems to happen with every parameter, so in effect I cannot edit materials.
Mapping of materials is screwy. It doesn't match the dimensions I specify in the SU texture. It seems to be off by a factor of 8x - 10x
Once a SU material is linked to an Octane mat I can't change from a bitmap in the diffuse to an rgb color.
Often, the Octane material parameter popup appears but is unpopulated. Then when/if it eventually appears, it is corrupted and all the buttons lock up or do strange things.
Anyway - I need to know if I'm doing something wrong, or if there is a patch, or if there is a previous version I should roll back to for now.
(2) Geforce GTX780-6GB | i7 5820/6800 | 32GB
Win 10-64 | Octane v3.05.3 | NVidia v381.65
jscottsmith
Re: Can't edit materials
Postby fuzzybro » Sat Oct 04, 2014 3:51 am
fuzzybro Sat Oct 04, 2014 3:51 am
Hi jscottsmith,
Thanks for the feedback!
I'll check all the issues next week.
fuzzy
fuzzybro
Postby fuzzybro » Wed Nov 12, 2014 8:51 pm
fuzzybro Wed Nov 12, 2014 8:51 pm
Hello jscottsmith,
Could you please provide the scene where this issues happened?
I tried to reproduce them without success.. everything seems to work fine.
Fuzzy
fuzzybro
Postby resmas » Thu Nov 13, 2014 11:25 am
resmas Thu Nov 13, 2014 11:25 am
fuzzybro wrote:Hello jscottsmith,
Fuzzy
Apart from random buggy empty material menu (solved with exit of group edit., and sometimes the need to restart SU) i dont report almost any crash.
Materials sometimes unlink, but can't find a reason/step to explain what i did. But 95% of times no problems :D
Cheers
Resmas
i7-2600k | SSD Vertex 3 | WD Velociraptor | WS Revolution | 16GB Ram HyperX | PSU LEPA G1600W | 3 X Asus GTX590 |
https://pt-pt.facebook.com/arq.resmas
resmas
Postby fuzzybro » Tue Nov 18, 2014 12:43 am
fuzzybro Tue Nov 18, 2014 12:43 am
Ah come on, post some scenes or provide scenarios! Let's make it 100%
fuzzybro
Postby resmas » Tue Nov 18, 2014 11:24 am
resmas Tue Nov 18, 2014 11:24 am
fuzzybro wrote:Ah come on, post some scenes or provide scenarios! Let's make it 100%
:D .... Ok Fuzzy i will try to post some screens or examples.
For now i upload the result. of a 95% working plugin :lol:
Cheers
Resmas
resmas
Postby fuzzybro » Tue Nov 18, 2014 9:04 pm
fuzzybro Tue Nov 18, 2014 9:04 pm
hey, 95% is a definition of 'beta' so we're doing really well :D
fuzzybro
Return to SketchUp
Mon Oct 26, 2020 9:26 pm [ UTC ]
cron
