Any specular material and fog - issue!?
nuno1980
Hi! :)
Any specular material (such as glass prism) does NOT contain fog but in space only.
The fog is inside the glass prism -> FALSE!
see screenshot:
Therefore, that isn't real life.
How do I eliminate fog inside the material?
PT vs PHT kernels - spp nrs
Caustics at PT
i7-12700KF
32GB DDR4@3600
GF RTX 4090 <3 :mrgreen:
NEW ACER Predator XB273U F5 27" :D
nuno1980
Please should respond - do not delay!! :?
Caustics at PT
i7-12700KF
32GB DDR4@3600
nuno1980
I'm sad because @FooZe ignores to reply here.
Caustics at PT
i7-12700KF
32GB DDR4@3600
FooZe
Hi Nuno,
Can you post the scene please?
glimpse
nuno, if I understand You right, You have fog..& glass in that fog? if so.. Your fog should have cube with inverted normals (& fog material) where Your glass Cube is =) but You have to play around with size of these cubes as You can't have to faces in the same plane.. in that way everything will be physical - there will be no fog in the glass =)
nuno1980
FooZe wrote:Hi Nuno,
Yes.
May do download scene obj free. ;)
prismdemo quadrangular with fog.rar
(9.06 KiB) Downloaded 468 times
Caustics at PT
i7-12700KF
32GB DDR4@3600
FooZe
Also, try making your emitter a single plane and placing it so that it covers the tube of the laser.
Make it so that your emitter is as simple as possible (a single plane) and that if a ray bounces down the tube of the laser it is guaranteed to hit the emitter.
nuno1980
Ooh! I forget to answer where is the laser point, sorry... :)
screenshot:
look laser point
Caustics at PT
i7-12700KF
32GB DDR4@3600
nuno1980
Are you still investigating?
Caustics at PT
i7-12700KF
32GB DDR4@3600
FooZe
Hi, Sorry, without the .ocs file I can't really test your exact scene (and you can't save the ocs with the demo).
It could very well just be that you are seeing the light that is hitting the ground/floor here, not fog inside the cube.
