Hi guys!
I am unable to use a image sequence as texture in octane render.
Does anyone have the same issue and if so, how can i get it to work?
Thank you!
Animated texture issues
Downtown Visuals - Architectural visualization. www.downtownvisuals.com
Version?
what happens when you try the imagesequence.c4d from samples package?
it works when i render the sample file, but when i make a new glossy texture, add a octane imageTexture, select the first frame of a sequence and then under animation insert the start and endframe and the frame rate, it renders everything out as a grey material...
you have to set start/end ranges manually. I'm checking everything is well. Where is your images? under project path or you set that as fullpath of images?
I'm having the same problem (ver2.05.0 rc1). The example works fine, but even when I edit a copy of the example(imagesequence.c4d file) to load a different .jpg sequence the new texture doesn't render at all.
Is there some trick to loading the images I'm missing?
- Monguilhott
I am having the same issue here. I downloaded a scene from the forum (emistex.zip) which contains an animated texture.
I only change the animated texture that is very similar to the sample project and get a grey box!
Is that a bug?
Octane 2.12.2
Is that a bug?
Octane 2.12.2
- Attachments
- emistex.zip
- (906.49 KiB) Downloaded 204 times
are you sure your image in under project path? check console output for a file error message
- Monguilhott
Yes, its in the project path. Where is the console output? Is the help/show octane log? Sorry beginner question.
- Attachments
- octane 2.12.1 141124 113448.log
- (2.85 KiB) Downloaded 214 times
can you try this on diffuse channel? lets see what's happening
