How to mix two textures by "screen".
R_Flash
Hi. I need mix two raster textures in material by "screen". I find only multiply. Cinema "layer" work with errors. Thanx!
Win7, i7 950, 12Gb RAM, GTX580
did you see mixtexture? It's for mixing two textures. you can put any other texture to amount slot or just use slider of amount
atome451
Indeed! With the base texture as texture 1, a RGB white as texture 2 and the "screen" texture as amount in a MixTexture node, you'll have the same result as screen fusion in Photoshop.
Win10 64bits | 3x 980 + 2x 670 + 1060 | Cubix XPander + network | Core i7 3600 MHz | 32GB | 1300w PSU
Sorry for my bad english...
R_Flash
Thanks guys! It`s worked
pavel3d
atome451, could you be so kind to provide an cinema scene with two textures mixed in "screen" mode.
I got two textures one is "asphalt" and the other is " white road marks", you said that "screen" should be placed in the amount channel, but there's no screen in octane :)
milanm
pavel3d wrote:atome451, could you be so kind to provide an cinema scene with two textures mixed in "screen" mode.
Hi
A while ago I made a few blending mode setups. There's much more than just screen. Check out the scene files. I hope that helps.
viewtopic.php?p=284085#p284085
Edit: also new 3.06 test release has this functionality built in so setups like this will not be needed in the future.
Regards
Milan
Colorist / VFX artist / Motion Designer
macOS - Windows 7 - Cinema 4D R19.068 - GTX1070TI - GTX780
blastframe
Here is a scene file with a texture using Screen Blend Mode:
Octane_ScreenMaterial.zip
(211.61 KiB) Downloaded 221 times
Nice but it's easier to do with OSL nodes anymore.
blastframe
aoktar wrote:Nice but it's easier to do with OSL nodes anymore.
Cool! I don't know much about OSL nodes. How would setting up a blend mode work? I searched the forum but didn't find anything.
Something like this, very simple.
https://en.wikipedia.org/wiki/Blend_modes#Screen
Octane_ScreenMaterial.rar
(245.25 KiB) Downloaded 238 times
