HELP! "Scene too large to load. Vertex Limit Reached
Boschie143
Hey guys,
I'm new to Octane Render, used the demo for Revit plugin..I just bought the full program with the Revit plugin, and when I try to render my one 3D view a pop up message comes up and states "Scene too large to load. Vertex limit reached"
Now I've used artlantis and 3Ds Max before and never got a issue..Can someone please help me here because I have no idea what to do, I can't even find a similar problem on the net nor on the forum??
My specs :
i7-3820
2 x Nvidia GTX770 (4Gb each)
16Gb 2333mhz RAM
256Gb SSD + 3TB WD Hard drives
Hi
Increase the "Max Number of Polygons" value in the configuration. Mouseover the settings for more details.
Boschie143
omw it was that easy..thanks so much! really appreciate the quick response! :D
SamuelAB
Where can I find this in the settings? I went through it all twice and could not find it. Using release 3.7.0.51.VR on Revit 2018.
Is it in the camera, env, film, animation, kernel, layer, passes, imager or post-processing settings?
It is in the Configuration panel (click the Setting button to open it).
SamuelAB
Hi Paul,
I do not see it. Could you tell me what category it is under or circle it in the image?
I've read this list 2-3 times by now and I cannot find it.
SamuelAB
Ah, nevermind. I found it. I got confused because there is a Setting tab and a Setting button.
Return to “Autodesk Revit”
