missing Hue, Contrast and Saturation filter
miohn
sorry if already posted.
Are there plans to integrate something like
the c4d "filter" shader?
The color-correction only has option to adjust brightness.
regards
Mike
miohn wrote:Hi,
regards
Mike
no, it's not possible to implemented from plugin. We should ask to Octane render team for native support.
miohn
Hi Ahmet,
ohh o.k.
Maybe you could ask Otoy to add
"Hue", "Saturation" and "Contrast" to the Color-Correction-Node.
Would be very helpfull!
thanks
Mike
gordonrobb
I've finally managed to suss out using teh Colurcorrection node for contrast, just lower the black point below zero and increase the brightness scale.
miohn
Hi thanks,
well this works somewhat.
But for me, more important would be saturation and hue.
regards
Mike
mattfrodsham
I agree, very important. One of my most missed shaders
Windows 8.1 / 4xGTX980 / C4D R18
useruser
same here. saturation is really important. i need that more or less every time if i work with an hdri-enviroment. the workaround for desaturating HDRI-Images with the "mix-texure-shader (blend between the normal and black-and-white_Version of a HDRI-Image) works but it disables the importance-sampling function in the HDRI-Environment-object so it slows the renderspeed extremely down.
Workstation: Win 10 PRO 64 bit, 3,4 GHZ ,6-cores, 64 GB RAM , 4x RTX 2080 Ti
1. RenderSlave: Win 10 Pro 64 bit , 3x GTX 980Ti
2. RenderSlave: Win 10 Pro 64 bit 2x GTX 980 Ti
