OctaneRender® for 3ds max® v1.11[Test]
Karba
NEW FEATURES SINCE LAST RELEASE:
  • Added architectural glass as option "fake_shadows" in the specular material node
  • Improved direct light calculation in SSS materia
  • Improved accuracy of intersecting volumes with different IORs - as a side effect volumetric noises don't work anymore
  • New multi-threaded mesh compilation with better render performance and lower memory usage during compilation (/voxelization)
  • New dirt texture node
  • New panoramic camera options for Octane Camera
  • Improved daylight system
  • Black edges in glossy materials are fixed
  • Surfaces with a matte material hiding all objects behind, but are visible indirectly
  • GPU priority settings to reduce 3dsmax viewport lags.
This version requires video driver 301.42 or higher.
Limitations on old cards
The PMC kernel and the matte material options don't work on old graphics cards (GTX 2xx, compute model < 2.0).
DOWNLOAD
We have 4 separate archives available for download, for Autodesk® 3ds max® 2010, 2011, 2012 and 2013.
Each archive contains the manual and installation text file, and both 32bit and x64 versions of the plugin,
so you only need to download one archive for your 3ds max® version from the following download links:
3ds max® 2010: http://www.refractivesoftware.com/plugi ... _v1.11.zip (50MB ZIP File)
3ds max® 2011: http://www.refractivesoftware.com/plugi ... _v1.11.zip (50MB ZIP File)
3ds max® 2012: http://www.refractivesoftware.com/plugi ... _v1.11.zip (50MB ZIP File)
3ds max® 2013: http://www.refractivesoftware.com/plugi ... _v1.11.zip (50MB ZIP File)
Yours,
The OctaneRender® Team.
Elvissuperstar007
thank you
New PMC kernel option "parallelism" it is not present?
Karba
Elvissuperstar007 wrote:thank you
Not yet. It uses default value 4.
Elvissuperstar007
ok)
tonycho
Thanks Karba :D
http://www.antoni3D.com
Win 7 64 |GTX 680 4 Gb (Display) | 3 x GTX690 4Gb | Intel i5 |Corsair 16GB
bicket
Thanks Karba
Lets try :mrgreen:
PortFolio
4 x TITAN - Win 7 64 - Octane Rocks
Vanya
Core i5 76o @ 2.8o GHz | ZOTAC gtx58o AMP 1536Mb | MSI gtx46o 1o24Mb | Corsair ForceGT SSD12o | Gskill 16Gb RAM 16ooMHz
JJTTBB
Great, thanks!
AutoCAD,Revit Architecture, Max Design (all 2012) , Moi3D,Maxwell Render,Octane Render
Intel i7-8Gb RAM - Win7x64 - GTX550Ti
Aaaaahole
Cheers Karba
Win7 64 | i7 870 @ 3.2GHZ | GTX 780 3GB | 16GB | Phantom Scatter |
suvakas
Thanks!
What happened with the idea of giving us more parameters to tweak the sky?
Is it in your to-do list?
Suv
Return to “Autodesk 3Ds Max”
