Home Improvement - Daylight Simulation
User avatar (Default)
ivankio
Finished a real time visualization and took the model to Octane to play with it for the first time. Glass and water were very important for this scene but both were needed to be left behind for the moment.
timelapse.flv
(423.64 KiB) Downloaded 5392 times
I'm sorry for the low res test at just 256 samples/pixels. 9600M GT here - about 7 hours for the 130 frames :lol: I'll get a workstation in a while.
Can't wait to put it to work seriously. Still, it's funny that the FLV compression did smooth out some grainy parts.
Screens from the interactive application:
radiance
I think it's awesome you managed to pull this off with such a slow GPU. ;)
nice work.
Radiance
ivankio
The work up until now is mostly yours. This thread is more likely a PIP (play in progress). Nothing much to see here but, for those addicted to flipbooks like me, here is a small fix until we get a real one :ugeek:.
timelapse2.flv
(965.87 KiB) Downloaded 5256 times
I grabbed the 1.022 2.2 and more 7 hours with 410 samples/pixel for the same 130 frames. I realised I could go with only 2 light bounces since it is mostly outdoor. Of course now I use the clay mode, but gloss didn't impact that much as the extra bounces in the first moment (default 7).
radiance
cool ;)
you should definately consider buying a faster GPU in the future...
Radiance
scandog72
Looks really cool
What software did you use to create your FLV?
I have been trying to use virtualdub to create and AVI of a turntable but not having much luck with the frame rates.
Vista 64|Q6600 2.4GHz|6GB|GTX260
ivankio
Scan, I used the trial of Premiere CS5. I haven't thought that much about cheap video publishing yet since now I work mostly with real time applications and used to work with Premiere at my previous work. But your search without results is unsettling. If I find anything, I'll message you.
brobo
That's pretty rad. I am guessing you just rotated the HDR image? Really good use of the software capabilities considering your GPU limitations.
BROBO.TV - Core i7 X980 @3.33Ghz | 32gb | Windows 7 Professional 64-bit | EVGA Geforce GTX Titan
Cinema 4d R14 + Octane 1.10
ivankio
No HDR image, I took the even easier way using Octane's daylight environment system.
Return to “Works In Progress”
