Version 4.0-RC7-R4 (obsolete release candidate) 10.11.2018
tomsvfx wrote:Hi Aoktar!
Thanks for implementing that feature that allows to save each render pass seperatly from LiveViewer, but its not saving alpha channel, transparent images comes out with black background.
Thanks for reporting. Most likely forgot alpha switch, I'll fix it.
Darkpulse
Just to let you know a possible issue. Some frames (as far as know, randomly) are stuck at 100% render (example, infos are displayed like 512/512 but nothing happens, maybe in the denoise step) into the render viewer. I have to stop the render and to restart from the frame who was stucked, and no issue to re-render the frame.
Configuration :
macOS 12.13.6
Cinema4D R20.030
2x GTX 1080
Octane C4D 4.0-RC7-R3
Cuda 410.130
NVIDIA Drivers : 387.10.10.10.40.108
Thanks for your feedbacks
Darkpulse wrote:Hi,
Configuration :
macOS 12.13.6
Cinema4D R20.030
2x GTX 1080
Cuda 410.130
Could you share a simple scene with problem?
Darkpulse
aoktar wrote:
Darkpulse wrote:Hi,
Configuration :
macOS 12.13.6
Cinema4D R20.030
2x GTX 1080
Cuda 410.130
Sorry but it's a for a client, I can't share the project files.
I can tell you it's also happens with another project, with the same configuration but with the previous V4 version.
I can't reproduce the situation, it's pretty rare to be honnest. It happens today and one time 2 days ago.
ArtyomPapikyan
Hi! Cannot install octane version 4.0-R7-R3 on Cinema 4d r20. Same problem with Standalone V4-RC7 . When the download cuDNN, you receive the error "the downloaded cdn is not what octane is expecting". What am I doing wrong?
Windows 10
ArtyomPapikyan wrote:Hi! Cannot install octane version 4.0-R7-R3 on Cinema 4d r20. Same problem with Standalone V4-RC7 . When the download cuDNN, you receive the error "the downloaded cdn is not what octane is expecting". What am I doing wrong?
Windows 10
what happen if you try to install cuDNN in C:\Users\<user_name>\AppData\Local\OctaneRender\thirdparty\cudnn_7_0_5 directory, from the following link:
https://render.otoy.com/downloads/1c/42 ... nn64_7.dll
ciao Beppe
Guy_frog
Hi Ahmet, this function convert to sub_material is really excellent! :) For this R3, I spotted some cases where settings are not yet transferred to the sub_material. I 'll sending you by PM a material with which this pb occurs: for Diffuse / Color and for Index / Rgb IOR: the second red value remains on 0.
Guy_frog wrote:Hi Ahmet, this function convert to sub_material is really excellent! :) For this R3, I spotted some cases where settings are not yet transferred to the sub_material. I 'll sending you by PM a material with which this pb occurs: for Diffuse / Color and for Index / Rgb IOR: the second red value remains on 0.
Thanks guy! I'm not surprised, too much things I'm working on together. Please send me which parts are missing. Btw I fixed another problems of converting mix materials to blend material. Will be there for next release.
tim_grove
Any update on displacement problems?
Prepared a fix on new build(4.0-RC7-R4)
viewtopic.php?f=85&t=69250
tim_grove wrote: Any update on displacement problems?
Not yet but It's not related with plugins. Better to ask in standalone forums. I believe there are some plans for issues.
