Thanks for reporting. Most likely forgot alpha switch, I'll fix it.tomsvfx wrote:Hi Aoktar!
Thanks for implementing that feature that allows to save each render pass seperatly from LiveViewer, but its not saving alpha channel, transparent images comes out with black background.
Version 4.0-RC7-R4 (obsolete release candidate) 10.11.2018
Just to let you know a possible issue. Some frames (as far as know, randomly) are stuck at 100% render (example, infos are displayed like 512/512 but nothing happens, maybe in the denoise step) into the render viewer. I have to stop the render and to restart from the frame who was stucked, and no issue to re-render the frame.
Configuration :
macOS 12.13.6
Cinema4D R20.030
2x GTX 1080
Octane C4D 4.0-RC7-R3
Cuda 410.130
NVIDIA Drivers : 387.10.10.10.40.108
Thanks for your feedbacks
Configuration :
macOS 12.13.6
Cinema4D R20.030
2x GTX 1080
Cuda 410.130
Could you share a simple scene with problem?Darkpulse wrote:Hi,
Configuration :
macOS 12.13.6
Cinema4D R20.030
2x GTX 1080
Cuda 410.130
Sorry but it's a for a client, I can't share the project files.aoktar wrote:Could you share a simple scene with problem?Darkpulse wrote:Hi,
Configuration :
macOS 12.13.6
Cinema4D R20.030
2x GTX 1080
Cuda 410.130
I can tell you it's also happens with another project, with the same configuration but with the previous V4 version.
I can't reproduce the situation, it's pretty rare to be honnest. It happens today and one time 2 days ago.
- ArtyomPapikyan
Hi! Cannot install octane version 4.0-R7-R3 on Cinema 4d r20. Same problem with Standalone V4-RC7 . When the download cuDNN, you receive the error "the downloaded cdn is not what octane is expecting". What am I doing wrong?
Windows 10
Windows 10
Hi,ArtyomPapikyan wrote:Hi! Cannot install octane version 4.0-R7-R3 on Cinema 4d r20. Same problem with Standalone V4-RC7 . When the download cuDNN, you receive the error "the downloaded cdn is not what octane is expecting". What am I doing wrong?
Windows 10
what happen if you try to install cuDNN in C:\Users\<user_name>\AppData\Local\OctaneRender\thirdparty\cudnn_7_0_5 directory, from the following link:
https://render.otoy.com/downloads/1c/42 ... nn64_7.dll
ciao Beppe
Hi Ahmet, this function convert to sub_material is really excellent!
For this R3, I spotted some cases where settings are not yet transferred to the sub_material. I 'll sending you by PM a material with which this pb occurs: for Diffuse / Color and for Index / Rgb IOR: the second red value remains on 0.
Thanks guy! I'm not surprised, too much things I'm working on together. Please send me which parts are missing. Btw I fixed another problems of converting mix materials to blend material. Will be there for next release.Guy_frog wrote:Hi Ahmet, this function convert to sub_material is really excellent!For this R3, I spotted some cases where settings are not yet transferred to the sub_material. I 'll sending you by PM a material with which this pb occurs: for Diffuse / Color and for Index / Rgb IOR: the second red value remains on 0.
Any update on displacement problems?aoktar wrote:Thanks guy! I'm not surprised, too much things I'm working on together. Please send me which parts are missing. Btw I fixed another problems of converting mix materials to blend material. Will be there for next release.Guy_frog wrote:Hi Ahmet, this function convert to sub_material is really excellent!For this R3, I spotted some cases where settings are not yet transferred to the sub_material. I 'll sending you by PM a material with which this pb occurs: for Diffuse / Color and for Index / Rgb IOR: the second red value remains on 0.
Prepared a fix on new build(4.0-RC7-R4)Guy_frog wrote:Hi Ahmet, this function convert to sub_material is really excellent!For this R3, I spotted some cases where settings are not yet transferred to the sub_material. I 'll sending you by PM a material with which this pb occurs: for Diffuse / Color and for Index / Rgb IOR: the second red value remains on 0.
viewtopic.php?f=85&t=69250
Not yet but It's not related with plugins. Better to ask in standalone forums. I believe there are some plans for issues.tim_grove wrote: Any update on displacement problems?
