Cinema 4D version 2019.1.4-R2(Obsolete stable) 07.12.2019
nejck
Hello peeps!
Am I the only one who can't get motion blur to work on this version? :o Just doesn't want to work no matter what I do. On a side note, a super slow shutter speed also reliably crashes Octane :)
nejck
Yep, still can't get the motion blur to work on this version or the 2020 XB1 Test 1 one. :\
nejck wrote:Yep, still can't get the motion blur to work on this version or the 2020 XB1 Test 1 one. :\
Be more specific, it's working as expected. No change for motion blur.
nejck
Sorry, I was being super concise with my other post because the issue is fundamentally concise - Turning on motion blur doesn't seem to work on my end. It just doesn't show up.
It is enabled in the render settings, in the liveviewer and it is enabled in the camera tag. The shutter speed can be super crazy but still can't get it to show up. I tried it in different scenes as well as completely new ones. I also tried the universal camera instead of the thin lense one. DOF and similar effects work nicely.
At this point I'm thinking I'm either having a giant brain fart or something isn't working as it should.
Does it work on your end?
I am on the Studio Drivers 441.28 :)
Motion blur seems to work as expected here:
Please, share an example scene that shows the issue, thanks.
ciao Beppe
nejck
My sincerest apologies to Aoktar and bepe4d, was a brain fart on my side. I must have accidentally changed the default scene scale and so I kept getting stuck with unrealistic values such as having the motion blur be so strong it actually doesn't show the object moving.
Woah that took a surprisingly long amount to figure out. Sorry for nagging you!
divasoft
Hello, when I connect a displacement to a setup with a vertex map, it stop to influence.
https://yadi.sk/d/skvPUGPWEciRdg
desire
Is option "static noise" now working or should I enable it in a different place than Render Settings?
When no motion, there is no moving of noise pattern frame by frame, but if I add even very slow moving of anything, render gives dancing pattern. Why?
desire
bepeg4d wrote:Do you have AI Denoiser active with low max samples?
ciao Beppe
Thank you for reply, bepeg4d
What is low max samples? What samples count I need?
Tried on two scenes - 300-400 samples with active Denoiser.
