Version 2.16.2
Easy to use. Use it in amount pin in a "mix texture". It will give 0 or 1 values by face orientation.illmonkey wrote:Cool thing about the side-texture, But I'm not sure how to use it. All it gives me are a "invert" parameter. In the nodegraph it shows me no inputs.
- kehrmaschine
aoktar wrote:2.16.1 is stabile candicate.kehrmaschine wrote:Ok.. I just updated to 2.16.1 because I had a problem with 2.06.
Now I can not render in 2.16.1.
When is this gonna be fixed?
Which version is best/stable for Win7 64 C4D R15? And where can I download it? I can only see 2.16 and 1.00 in customers area...
Do you see any other criticism about stability here? Please post more info about problem to help to you.
Please don't post on several places. This makes me confused. I think you should set this default environment color as in image.
Also post images to describe better your problems. I cannot estimate what happens.
alright.
I cant render.. after restarting windows it says there is no cuda device. I also cant find and graphicscard settings in octane settings anymore. I have a gtx 780 6gb and worked with octane until today.
Hi Ahmed,
since 2.16.2 is running stable and nice one problem occurs in LiveDB: when choosing category "Misc" in Materials Cinema crashes. Other categories are fine.
Bug report attached.
Greetings
Ron
Greetings
Ron
- Attachments
- _BugReport.zip
- (53.02 KiB) Downloaded 260 times
Master: WIN 10 64bit, i7 4930 4,5 Ghz, 64 GB RAM, 1600 W PSU, 1 TB SSD, 14 TB RAID, 2 x RTX 3090
Two small issues in 2.16.2 (as in older versions like 2.14 and 2.12 also)
- Scenes with Background Objekt rendering a white outline between objects and Background
- When shutting off Cinema via the cross instead of menu, it still stays open in Task Manager and can't be restarted as long as it isn't shut down in TM. This is only with Octane as plugin, without Cinema will completely close. There are different scenarios, this is always when Octane has been already used in a scene and also has rendered before.
Edit: another method to completely close Cinema is to change the layout back to a standard one. I'm using my own for Octane. Changing back to "Start" and closing Cinema with the cross icon will do also.
| Win 11 | 64 GB RAM | AMD 5900X | RTX 3090 24 GB | C4D R21 | C4D-Octane v2026.1 |
It would be nice if the default environment automatically disabled when a light is added to the scene, as it does in C4D. Just a thought. I have been having the two issues dinf mentions in all 2.16 releases.
Win 8.1 / C4D R16 / Maya '16 / 5x GTX 980 Ti
Please try to add more info about crashes, versions. It's mentioned on release notes. What happens when you delete "livedb" folder?Kemanjo wrote:Hello.
I have C4D crash almost every time i try to open liveDB and find there any material in categories.
here:
C:\Users\USERNAME\AppData\Roaming\MAXON\Cinema4Dr15_AAAAAA\prefs\livedb
