Version 2.16.2
Hi everybody,
i'm glad to publish the version 2.16.2 which is based on Octane sdk 2.16.0. Contains all changes of standalone 2.15 and 2.16.
See standalone 2.15 here: http://render.otoy.com/forum/viewtopic.php?f=33&t=43923
See standalone 2.16 here: http://render.otoy.com/forum/viewtopic.php?f=24&t=44074
Download is updated with 2.16.2 version. It has some fixes which have been reported by users.
- Fixes for localdb crashes and missing textures.
- Fix for back/foreground objects.
- Bug on kernel overwrite section.
- A few minor fixes done about workflow over last 2.16.1 test versions
- Fix for black environment issue on clean install
-changes since 2.14.0
- Fstop and iso has been deprecated from camera imagers. Plugin will try to convert this parameters for old scenes.
- Reduced the brightness of the daylight environment by a factor of 0.6 for the new daylight model and 0.8 for the old model. Plugin will try to convert this parameters for old scenes.
This way there is a better match between the texture environment and the daylight environment. Or in other words: Exteriors rendered with
the default exposure settings are less overexposed than before. Older scenes will be converted automatically and should render the same.
- Performance and memory usage improvement on render instances. Removed double mesh usage by some optimisations.
As a result, it will be much faster on scene compilation and consume less vram usage for render instances.
- New options for emission texture. Cast illumination and surface brightness. These will allow to use without casting illumination.
- New parameter for side texture.
- Render region has been improved on live viewer. Now all interactive modes should work when render region activated.
- Settings are fixed to allow the changes of parameters during animation rendering.
- Fixed losing material links while switching between scenes.
- File saving for render passes, it has been fixed.
- Fixed some problems on Render queue
- Better object selection throught Live viewer interface
- Fixed lock resolution button behaviour
- New slider type like C4D's default sliders. Even it's possible to use C4D's own sliders. Please see settings->other->slider options. Select type and press "Apply" button. Changes between C4D-Octane types, needs a restart.
- Added LocalDB category to Livedb window. This is a special category. It allows to share your materials between standalone and plugins.
- Object tag. Some revisions for upcoming versin(2.20). It's related with render layer system. Currently "layerId" and "random color seed" is unfunctional. Let's keep it here.
Note about "new.c4d" or "default.c4d" usage. If you have this scene as startup which is done by old version. Please create new one with current version to avoid a warning window.
IMPORTANT INSTALL NOTES:
Due to the switch to CUDA 6.5 you will need a current graphics driver of version 344.x or higher. On Mac OSX you will need a CUDA driver of version 6.5 or higher (see http://www.nvidia.com/object/mac-driver-archive.html). The minimum supported version of Mac OS is 10.7.
Also matching version of Standalone 2.1x is highly recommended.
And remove all old plugin files before installing. Any version conflict or old drivers can cause crashes
Cuda driver for Macos: http://www.nvidia.com/object/macosx-cud ... river.html
BUG REPORTS
I'll be happy, if anyone can be spesific with bug reports.
I need to know that plugin version/Os/HW, bugreport zip. Last operations before crashes.
Please post your reports in topic of version which is related.
Thanks for contributions
Best regards,
Ahmet Oktar
2.16.2 Windows version (R12-R16)
http://render.otoy.com/customerdownload ... .2-win.zip
2.16.2 MacOsX version (R13-R16)
http://render.otoy.com/customerdownload ... Macosx.zip
Demo scenes for 2.00
http://render.otoy.com/customerdownload ... amples.zip
Demo scenes for 1.50
Facebook page:
https://www.facebook.com/octaneforcinema4d
Also a new commercial training set by InlifeThrill Designs
http://inlifethrill.com/trainings/octan ... cinema_4d/
usage of Render passes
[vimeo]http://www.vimeo.com/112409526[/vimeo]
Speed test on new impromevements on object update detection
[vimeo]http://www.vimeo.com/108597468[/vimeo]
A new free tutorial by Christof
[vimeo]http://www.vimeo.com/108846254[/vimeo]
NET RENDER document: http://render.otoy.com/manuals/Standalo ... ge_id=1248
Supported features:
Displacement(activate with displacement checkbox in properties)
Hair rendering
Full motion blur for geometry and camera
Rounded edges
Opensubdiv
Render regions
Distributed rendering
Daylight+texture environment
Random color texture for instances
Render passes
[vimeo]http://www.vimeo.com/108696569[/vimeo]
rodross
Thanks for the update!! Excited about the luminance texture without emission. Been needing that one for awhile. What's a "side texture"? And what did you do to the Object tag? Just says object tag.
rodross wrote:Thanks for the update!! Excited about the luminance texture without emission. Been needing that one for awhile. What's a "side texture"? And what did you do to the Object tag? Just says object tag.
sorry fixed the text about object tag.
I found that cast illumination is one of most usefull options.
Side texture is for mapping two different texture to front/back faces. Object tag revisions are related with upcoming object buffer system. And hopefully a little about mograph shaders.
schodt
I just installed this version. When trying to open the LiveDB via the Live Viewer, my Cinema 4D freezes. I'm on R15.
Workstation: Watercooled 4x GTX 780, 1500W Corsair AX1500i PSU, 4930K, 32 GB RAM, SSD and Cinema4D.
Render slave: 4X GTX 780 Asus Strix 6GB, 1200W Corsair AX1200i PSU
schodt wrote:I just installed this version. When trying to open the LiveDB via the Live Viewer, my Cinema 4D freezes. I'm on R15.
what do you have on database? localdb materials or any materials under category "USER"?
schodt
In standalone I have a few materials which I've saved in the localDB.
schodt wrote:In standalone I have a few materials which I've saved in the localDB.
try without this materials. If it's gone please send me there materials to me. What was the previous plugin/standalone version?
schodt
OK just deleted the materials from standalone, still having the same problem, it's still not opening the liveDB in C4D. What should I send to you?
schodt wrote:OK just deleted the materials from standalone, still having the same problem, it's still not opening the liveDB in C4D. What should I send to you?
nothing. What do you see here?
C:\Users\USERNAME\AppData\Roaming\MAXON\Cinema4Dr16_xxxxxxx\prefs\liveDB
try to move all to temp folder and clean here. Then try again. If it's gone try to send me this content
schodt
Just moved that folder out, and now the liveDB opens! Thanks aoktar!
