Ok, thanks for the report. The issue was that the reported image texture data size was complete junk. It will be fixed with the next release.smicha wrote:Actually I don't know when exactly it happened but it did. Here is the screenshot. And what funny is that total vram for my Titan is 12GB - nvidia was so generous giving me extra 6GBSeriously, after reloading the obj all went back to normal.
OctaneRender™ Standalone 1.22
No problembepeg4d wrote:great!!! it works, thanks for sharinggardeler wrote:Great hack to get your timeline back!
If you have an alembic file in it, but the timeline was gone when you opened it? Just select your alembic node and press ctrl + c, and viola!!
enjoy!
Update about the focus distance import from Alembic: there was apparently a mistake in the Alembic documentation. So the next version of Octane should load the focus distance correctly. Note that for correct depth of field it is still necessary to specify the correct unit to be used for import.
Roeland
Roeland
I'm using both Windows 7 and Windows 8 64 bit, the same problem. Maybe it's a localization issue?roeland wrote:I can't reproduce this here, at least on Windows 7 it correctly picks a material at the pipette tip here. Are you also using windows 7?arh-osa wrote:Thanks!
Color linearization now works great!![]()
But there's one more issue in a material picker (in both 1.21 and 1.22). It grabs a pixel at the center of the cursor, not at the pipette tip.
Roeland
Here's a screencast
http://www.youtube.com/watch?v=Fm4RN3nerxc
SketchUp Pro 8/ Maya 2012 / W7 64bit / Intel i7 870 / 8GB / 2*GeForce gtx 680 4GB
Hi, there's a way to connect all the pins to a object layer?...in some geometry they are a lot! tnx
Intel Core i7 950\Zotac ION 512 mb, 1 Gainward 780 ti 3 gb\ 12 gb\ W7
Haven´t played with, but with lua it shouldn´t be a problem to realize it, i think...Area D wrote:Hi, there's a way to connect all the pins to a object layer?...in some geometry they are a lot! tnx
Don´t ask me for an example
face
http://vimeo.com/user2509578
enjoy!
Thanks mate...i was lost there.
If anyone can tell me...i think it will be a noob question but
Sorry for the most likely dumb question....
cheers
resmas
i7-2600k | SSD Vertex 3 | WD Velociraptor | WS Revolution | 16GB Ram HyperX | PSU LEPA G1600W | 3 X Asus GTX590 |
https://pt-pt.facebook.com/arq.resmas
- Elvissuperstar007
- Contact:
pipette material does not work
http://render.otoy.com/forum/viewtopic.php?f=73&t=37387resmas wrote:If anyone can tell me...i think it will be a noob question but...i cant figure it out....How do we render the animation from the alembic? for exemple the "octaneshatter121.ocs" animation...if i want to render it. how can i do it?
Sorry for the most likely dumb question....![]()
cheers
resmas
double post, sorry
