OctaneRender™ Standalone 1.22
abstrax
smicha wrote:Actually I don't know when exactly it happened but it did. Here is the screenshot. And what funny is that total vram for my Titan is 12GB - nvidia was so generous giving me extra 6GB :) Seriously, after reloading the obj all went back to normal.
Ok, thanks for the report. The issue was that the reported image texture data size was complete junk. It will be fixed with the next release.
gardeler
bepeg4d wrote:
gardeler wrote:Great hack to get your timeline back!
If you have an alembic file in it, but the timeline was gone when you opened it? Just select your alembic node and press ctrl + c, and viola!!
enjoy!
great!!! it works, thanks for sharing ;)
ciao beppe
No problem :)
roeland
Update about the focus distance import from Alembic: there was apparently a mistake in the Alembic documentation. So the next version of Octane should load the focus distance correctly. Note that for correct depth of field it is still necessary to specify the correct unit to be used for import.
Roeland
arh-osa
roeland wrote:
arh-osa wrote:Thanks!
Color linearization now works great! :)
But there's one more issue in a material picker (in both 1.21 and 1.22). It grabs a pixel at the center of the cursor, not at the pipette tip. :?
I can't reproduce this here, at least on Windows 7 it correctly picks a material at the pipette tip here. Are you also using windows 7?
Roeland
I'm using both Windows 7 and Windows 8 64 bit, the same problem. Maybe it's a localization issue?
Here's a screencast
http://www.youtube.com/watch?v=Fm4RN3nerxc
SketchUp Pro 8/ Maya 2012 / W7 64bit / Intel i7 870 / 8GB / 2*GeForce gtx 680 4GB
Area D
Hi, there's a way to connect all the pins to a object layer?...in some geometry they are a lot! tnx
Intel Core i7 950\Zotac ION 512 mb, 1 Gainward 780 ti 3 gb\ 12 gb\ W7
face
Area D wrote:Hi, there's a way to connect all the pins to a object layer?...in some geometry they are a lot! tnx
Haven´t played with, but with lua it shouldn´t be a problem to realize it, i think...
Don´t ask me for an example ;)
face
http://vimeo.com/user2509578
resmas
enjoy!
Thanks mate...i was lost there. ;)
If anyone can tell me...i think it will be a noob question but :? ...i cant figure it out....How do we render the animation from the alembic? for exemple the "octaneshatter121.ocs" animation...if i want to render it. how can i do it?
Sorry for the most likely dumb question.... :oops:
cheers
resmas
i7-2600k | SSD Vertex 3 | WD Velociraptor | WS Revolution | 16GB Ram HyperX | PSU LEPA G1600W | 3 X Asus GTX590 |
https://pt-pt.facebook.com/arq.resmas
Elvissuperstar007
pipette material does not work
resmas wrote:If anyone can tell me...i think it will be a noob question but :? ...i cant figure it out....How do we render the animation from the alembic? for exemple the "octaneshatter121.ocs" animation...if i want to render it. how can i do it?
cheers
resmas
http://render.otoy.com/forum/viewtopic.php?f=73&t=37387
ciao beppe
