MAX2Octane exporter for max 2010+
simmsimaging
I have applied unique materials to each object - that's what I did from the start. Unfortunately it's not helping so there must be something else going on with my approach or with the current exporter/release combo?
b
http://www.simmsimaging.com
blog.simmsimaging.com
i7 980 24GB Ram GTX580 3GB Vista 64 Ultimate
Jaberwocky
By the way.when in said the obj exporter i meant from the export menu.Not from the plug in.I have not been using that.It currently bombs out on me.If you have been using the export obj button within the plug in.Try the export of the file menu in max insted and use the .obj drop down from that.
kilaD
Sorry i've been afc for some days.
It works here with the latest pre 2.3_4. And yes give each objects you want to seperate a unique material
Hello
simmsimaging
I have done that. Anything else that it could be?
b
simmsimaging
Just verified - it is not working via the exporter but if I manually export the same meshes it imports fine into Octane - I just lose the camera that way.
b
Jaberwocky
Just had an idea.The Plug in was not working for me....that is untill i decided to try max 2010 - 32bit version rather than the 64bit version of max 2010.....IT works now.. There must be some incompatability using the plug in with the 64bit version.Not sure what.Still...at least it's working now.
simmsimaging
Im using 2011 64bit.
simmsimaging
No one else having this issue?
b
Proupin
eh... standard materials? note that vray materials (and mr i guess) are converted to a single default material when exported to obj.
kilaD
yes i should have clarified.. use standard materials.
simmsimaging:
does max2octane export the obj at all?
if not, try the attached version see if it helps.
(open in maxscript, press ctrl+e to open)
k
max2octane_objexp.rar
(6.48 KiB) Downloaded 284 times
Hello
Return to “Autodesk 3Ds Max”
