OctaneRender™ Standalone v1.03 (obsolete)
- MaTtY631990
Bug with ridged fractal. Changing omega just brightens the material and changing lacunarity does not do anything.
- princedragoncok
This release does not run on my Geforce GTS 250M GPU (older generation GPU). I tested it with the 3ds Max 1.02 plugin. Blank screen renders. Eagerly looking forward to an update + especially shadow catcher compatibility on the older generation GPU's. Many thanks!
Any infos if Subdivision Srfcs at render time will be implemented soon?
I wonder if this feature would not make the required VRAM amount on GPU unpredictable ?Any infos if Subdivision Srfcs at render time will be implemented soon?
If I understand well this feature, polygons non existing in the loaded OBJ file would be created in the renderer (several levels available, probably). Applying this subsurf tool could lead to a memory overload if there is not enough remaining VRAM.
Am I wrong ?
I think if this would work smart it could increase the polygon size only of the objects that are visible for the camera.
I still have the same problem with it showing that it is loading something after it has fully loaded it. I attached a simple scene and removed all the materials so I can just give you the .obj and octane files.
One thing I did do was rename the .obj and save it to a new file. (dont know if this would have caused this).
For me, this file continues to show it is compiling the mesh after it has clearly finished.
- Attachments
- loading error.rar
- (296.49 KiB) Downloaded 135 times
