Cinema 4D version 2019.1.1-R3 (Stable) 09.10.2019
roinigo
VVG wrote:
roinigo wrote:
Indeed... Does the Studio DRIVERs are preferable for Octane Render ?
yep, Studio more stable.
...too bad for me... :(
ASUS PRIME X470-PRO
AMD Ryzen 7 2700X 8 cores
Noctua NH-U12S SE-AM4
G.SKILL FLARE X SERIES 64 GO (4X 16 GO) DDR4 2933 MHZ CL16
RTX 2080 Ti + GTX 980
Seasonic PRIME 1000 W Gold
Fractal Design Define R6
Kalua
pxlntwrk wrote:Hi and thanks,
it works by disabling the materials preview. :D
Overview in the material manager remains grayed.
on the other hand when I test only with the 2080ti, everything works even with the feature "material preview" enabled,
but the preview becomes black, which is not a normal behavior compared to the old version where the preview remained white?
Disabling material preview also works for me.
C4D 2025.3.3 Octane v1.9.4 // Octane SA 2026.4, Windows 11 Pro, X399, AMD TR 2950X, <<2 X 3090 + NVlink>>, 128 GB RAM, Corsair 1500i - NVIDIA SD 610.62
Octane User since V1 Beta
adamwhatelse
Worked for me as well! thx aoktar... as always!!
cyrillweiss
Would you provide a demo version please?
cheers
HW01:WIN10x64/X79/i7-3930K/64gb/GPU:1xTitan X, GTX 1080ti, SW:Maya2018/2019, Cinema 4D R20
HW02:WIN10x64/Z370/i7-8700K/64gb/GPU:1xTitan X, GTX 1080ti SW:Maya2018/2019, Cinema 4D R20
etc. ...
cyrillweiss wrote:Would you provide a demo version please?
cheers
Not a good time for that
Kalua
Hi, Aoktar
Considering this reported issue: Is it possible to have a buttom to enable or disable shaders previews individually? Instead of disabling all shaders previews.
Thanks for your great work.
Hi, Aoktar
Yes I think that's not hard to add
KlaNDaH
I have some strange problem when using this new release and the scattering medium. If I load the scene from V4 to the new one it renders with a complete different and much lower SSS effect. I'm not sure if this is a bug or the engine has changed somehow and previous settings are not valid?
This is how it was looking in V4
render in octane 4
render in octane 4
This is 2019
render in octane 2019
Any idea why this happens?
Kalua
KlaNDaH wrote:I have some strange problem when using this new release and the scattering medium. If I load the scene from V4 to the new one it renders with a complete different and much lower SSS effect. I'm not sure if this is a bug or the engine has changed somehow and previous settings are not valid?
This is 2019
Try to play with the Scattering Depth. It was not present in V4.
KlaNDaH
The attachment dentin-octane4.jpg is no longer available
This is 2019
The attachment dentin-octane2019.jpg is no longer available
Makes no difference, I tried even at maximum depth and does nothing
