Cinema 4D version 2019.1.1-R3 (Stable) 09.10.2019
Hi all,
This is new build with a stable version of 2019.1.1 SDK.
Any feedbacks are welcome for development and fixing the issues. Enjoy it!
This is the matching SDK for the 2019.1.1.
See all new features of 2018/2019 versions.
To use this version, you need a GPU of compute model 3.0 or higher. Support for Fermi GPUs (like GTX 4xx and 5xx) has been dropped. Also, make sure you use a driver of version 419.xx or higher and if you are working on Mac OS that has a CUDA driver installed that supports at least CUDA 9.1.
1- Try different drivers, some of them could cause instability issues. Do a clean install while doing this to be sure previous files completely removed.
Changes of 2019.1.1-R3
- Keeping node attributes in localdb materials.
- Fix: Hang issue in quit phase after some specific operation
- Fix of some missing livedb material convert functionalites
- Small fixes for nodes
Changes of 2019.1.1-R2
- Missing transmission type in universal material
- Fix: (De)select all passes button
- Added: Motionblur support on splines with ObjectTag->Hair render
- Fix: update issue for R21 material previews due to changes of R21 SDK
Changes since OctaneRender 2019.1:
Fixed incorrect rendering of net render slaves.
Fixed crash when trying to render preview if a material that uses vertex displacement.
Fixed the diffuse channel of the metal material node to render black if it's not connected.
Fixed render failure in the material preview of shadow catcher materials.
Fixed anisotropy not working with values ranged between [-1 .. 0).
Fixed render failure when rendering volumes with scattering media.
Fixed fall off node not taking bump/normal map into account.
Fixed dielectric 1/IOR map not working with dielectric layer.
Fixed incorrect rendering of sheen when the diffuse and specular channels are both 0.
Fixed incorrect compilation of OSL code in some cases.
Fixed legacy volume render not matching between 2018.1. (To enable the legacy mode tick Emulate old volume behavior in the kernel settings)
Disabled AI upsampling if the output is a linear (unclamped) HDR image, because it is currently not supported.
Changes of 2019.1-R2
- Fix: Wrong material layer connection for downloaded materials from LiveDB
Changes of 2019.1
Contains the all fixes of latest 4.05/2018.1 plugins.
Known problems:
- Disable node previews if you wish to use displacement mixer, that causes crashes on previews.
- Corrupt render passes with up-sampling.
- Material preview issue on R21.
- Backward compatibility issue on Scatter object with R21
Changes of 4.05-R2
- Fix: Ignored "normalize" parameter of Octane Light tag
- Fix: Performance issue on Volume object when use empty filename
- Improved material/tag/object import/update on Node Editor
- Fixed some problems on R21 for Node Editor
Changes of 2019.1-RC3
- Fix: max value=254 for render_layer_mask pixels with PNG
- Added OslBaking Camera
- Improved Node Editor support for Octane objects and Octane tags
- Small change on InstanceColor
WINDOWS ENTERPRISE BUILD (R15-R21)
https://render.otoy.com/customerdownloa ... R3-win.rar
WINDOWS SUBSCRIPTION(Studio) BUILD (R15-R21)
OSX ENTERPRISE BUILD (R15-R21)
https://render.otoy.com/customerdownloa ... Macosx.zip
OSX SUBSCRIPTION(Studio) BUILD (R15-R21)
R15-res.rar
RES file for R15
(15.35 MiB) Downloaded 851 times
WINDOWS DEMO-BUILD (R15-R21)
https://render.otoy.com/plugindownloads ... R3-win.rar
OSX DEMO-BUILD (R15-R21)
https://render.otoy.com/plugindownloads ... Macosx.zip
Requirements:
-You'll need to update your Cinema 4D to latest versions(R16.050, R17.053, R18.057, R19.053, R20.057, R21.022). Otherwise, the plugin will not work and not appear in menus.
-Updated Nvidia drivers at least Nvidia Studio Drivers(419.x/431.xx) and be careful with latest Game Ready drivers which can cause cuda errors. Avoids to use 418.81.
-Cuda 9.1 driver for OSX.
ONLINE HELP MANUAL
To use OFFLINE version of manual from plugin
Download following package and extract to Cinema4D/plugins/c4doctane/manual
https://render.otoy.com/plugindownloads ... p-html.zip
V3 SAMPLE SCENES SET(make a request if you need any specific sample)
https://render.otoy.com/plugindownloads ... scenes.rar
See this topic for some partial samples: viewtopic.php?f=85&t=53989
CINEMA 4D TUTORIALS SECTION: viewforum.php?f=87
CHANGE LOG: https://docs.otoy.com/#60Change%20log
Installation
Ex. if you have Cinema4D R18.0, keep only "c4dOctane-r18.cdl64" and delete c4dOctane-r17.cdl64, c4dOctane-r16.cdl64, c4dOctane-r15.cdl64, etc..
Cinema 4D Release 15: c4dOctane-r15.cdl64 or c4doctane_R15_demo.dylib
Cinema 4D Release 16: c4dOctane-r16.cdl64 or c4doctane_R16_demo.dylib
Cinema 4D Release 17: c4dOctane-r17.cdl64 or c4doctane_R17_demo.dylib
Cinema 4D Release 18: c4dOctane-r18.cdl64 or c4doctane_R18_demo.dylib
Cinema 4D Release 19: c4dOctane-r19.cdl64 or c4doctane_R19_demo.dylib
Cinema 4D Release 20: c4dOctane-r20.xdl64 or c4doctane_R20_demo.xlib
Cinema 4D Release 21: c4dOctane-r21.xdl64 or c4doctane_R21_demo.xlib
pxlntwrk
shadow catcher seem Broken.
Create Material, unable shadow catcher > render failure
c4doctanelog.txt
(87.4 KiB) Downloaded 721 times
pxlntwrk.net
Silverwing
Network rendering in fundamentally flawed in this release.
Just open a new scene and render a cube with network rendering enabled. The slaves contributions will show up tinted in all sorts of colors.
It also behaves this way if I export the cube in Standalone.
WIN 11 PRO 64 | ASUS X299 SAGE | 1X RTX 4090 3X RTX 3090 | i7 10980XE | 128GB RAM
pxlntwrk wrote:Hi,
How could you decide that's broken? It's working on my trys. What's your driver version? It may be a problem with your setups.
Silverwing wrote:Network rendering in fundamentally flawed in this release.
Network or similar core functionalities not related to plugins. Better to move your post to standalone topic.
pxlntwrk
aoktar wrote:
pxlntwrk wrote:Hi,
Sorry for the vocabulary, "broken" may not be the ideal word ;)
Studio drivers 431.86
pxlntwrk.net
pxlntwrk
aoktar wrote:.... It may be a problem with your setups.
may be,
it works with the last OctaneRender-for-C4D-2018_1_3_R3_win and it worked also with the 2019.1-RC3_r2 (Test build) - 16.08.2019
  and the oddly I have this error (see logs above) with this version even with a newly created empty scene.
pxlntwrk.net
SSmolak
Is there will be special version for R21 and demo ?
SSmolak wrote:Is there will be special version for R21 and demo ?
what you mean by special version for R21?
SSmolak
At the moment download link says "WINDOWS ENTERPRISE BUILD (R15-R20)". Before stable release it was R15-R21.
