OctaneRender® for 3ds max® v4.00 - 6.11 [OBSOLETE]
DartFrog
Is there a way to save a beauty pass (or de-noised beauty pass) *without* the volume? and have the volume only as a seperate pass that renders at the same time? Similar to the post processing pass.
paride4331
Hi Dartfrog,
you can do it with two renders using Render layer ID.
Regards
Paride
mbetke
Why is my 3dsmax crashing several times a day when I just press the button to open material library? Its so annoying. :evil:
I loose so much time working...
PURE3D Visualisierungen
DartFrog
Hi Dartfrog,
Regards
Paride
Ideally you'd want to do it with one render - which is why I asked. I mean technically I could do it with two renders by rendering my scene with fog and without fog and then just blend them in photoshop.
paride4331
DartFrog wrote:
Hi Dartfrog,
Regards
Paride
Hi Dartfrog,
you can do it, then you have to use render passes.
Regards
Paride
DartFrog
Hi coilbook,
this option will be with next 3dsMax plugin release,
Regards
Paride
That's from a RC4 thread, regarding the "expected exposure" bug where it has to be 1 or 2, instead of .3 - And the rendering is locked at one sample only.
It is still a problem in 6.11. Wouldn't there be a way to completely bypass having to set this anyway?
coilbook
DartFrog wrote:
Hi coilbook,
Regards
Paride
I agree. I mentioned this problem like 10 times and it just gets ignored
coilbook
max crashes when element is cloned while octane viewport is opened
