OctaneRender® for 3ds max® v4.00 - 6.11 [OBSOLETE]
- paride4331
Why is my 3dsmax crashing several times a day when I just press the button to open material library? Its so annoying.
I loose so much time working...
PURE3D Visualisierungen
Ideally you'd want to do it with one render - which is why I asked. I mean technically I could do it with two renders by rendering my scene with fog and without fog and then just blend them in photoshop.Hi Dartfrog,
you can do it with two renders using Render layer ID.
- paride4331
Hi Dartfrog,DartFrog wrote:Ideally you'd want to do it with one render - which is why I asked. I mean technically I could do it with two renders by rendering my scene with fog and without fog and then just blend them in photoshop.Hi Dartfrog,
you can do it, then you have to use render passes.
That's from a RC4 thread, regarding the "expected exposure" bug where it has to be 1 or 2, instead of .3 - And the rendering is locked at one sample only.Hi coilbook,
this option will be with next 3dsMax plugin release,
It is still a problem in 6.11. Wouldn't there be a way to completely bypass having to set this anyway?
I agree. I mentioned this problem like 10 times and it just gets ignoredDartFrog wrote:That's from a RC4 thread, regarding the "expected exposure" bug where it has to be 1 or 2, instead of .3 - And the rendering is locked at one sample only.Hi coilbook,
