OctaneRender® for 3ds max® v2.11.1
Karba
3dgeeks wrote: Is there still a plan to have a displacement override as I havent see it in the new build?
We are thinking about it.
Karba
bicket wrote:Thanks Karba
is there a way to have passes in OctaneRender Viewport ?
Just click port to max framebuffer button.
Karba
ka-ra wrote: The Eneable filtering option doesn't work in the render element.
What does filtering do?
Karba
3dgeeks wrote:Is it possible to add more passes, ie Mat ID pass, zdepth.
I will add them.
Karba
Spdo wrote:Hi Kabra when the render elements acvtive the octane render viewport says render is failed
Where can we use render elements save in the re menu or use standart render f9 on the 3ds max
What is the best way ?
Thank you.
You are out of gpu memory. look at memory statistic.
bicket
Thank for your answer, but no way to see it in real time just like the standalone :(
PortFolio
4 x TITAN - Win 7 64 - Octane Rocks
Karba
gabrielefx wrote: - I would like to know if it's possible to have coherent feature within the PMC kernel.
pmc works differently from PT and DL. we are working on it.
gabrielefx wrote: - If it is possible to have convergence (focused caustics) within the PT kernel
PT doesn't render caustic well
gabrielefx wrote: - I'm always asking for target ies lights since when I was born....:)
3ds max target objects are a pain in my ass (sorry). They are so overcomplicated.
gabrielefx wrote: - If is possible to visualize the render passes through a menu in the Octane frame buffer windows. I want to focus only on the frame buffer.
press port to max framebuffer button
gabrielefx wrote: - if it's possible to add a superimposed (independent by the camera) brightness, contrast, gamma, hue, saturation directly on the frame buffer gui.
I will think about it
gabrielefx wrote: - if it's possible to have a white thin frame in the Octane frame buffer when the alpha channel is enabled. Now the checker board pattern has infinite boundaries.
regards
I will add it.
Karba
I will think what I can do.
HHbomb
I can't manage to make a render region in octane viewport with netrender. Is it a bug ? or an octane limitation ?
When region is active the render continue but the viewport is not updated. :cry:
Spdo
Thank you.
So what can i do ?
Locked
