OctaneRender® for 3ds max® v2.11.1
Karba
Main changes since version 2.10
  • Render passes/elements.
  • Region render for production render.
  • Added highlight compression option to camera imager node. Using this option, you can reduce burned out highlights by compressing them (which decreases their contrast). This works similar to the Reinhard tone mapping.
  • Added pins "hue", "saturation" and "contrast" to the color correction node to control hue, saturation and contrast of the input texture. Since Octane textures are sampled spectrally, hue and saturation don't work perfectly, but as long as you use them not too aggressively they should do the trick. We might have an idea how to improve that, but that will require some more work.
  • We had to remove the pins "brightness scale" and "black level" since we ran out of fields in our color correction shader node.
  • Added new noise texture node which currently has 4 noise types: "Perlin", "Turbulence", "Circular" and "Chips". "Perlin" is like the turbulence node with "use turbulence" disabled. "Turbulence" is like the turbulence node with "use turbulence" enabled. "Circular" is a Worley noise and "Chips" is a Voronoi noise.
  • Fixed hanging render kernels for some displacement cases (causing some of the dreaded CUDA errors).
  • Fixed hair normals.
DOWNLOAD
Installer http://render.otoy.com/plugindownloads/ ... 2_11_1.zip (30MB ZIP File)
For network slave and daemon please download standalone installer here
http://render.otoy.com/forum/viewtopic.php?f=33&t=42854
Yours,
The OctaneRender® Team.
rfox
Thanks Karba!
3x GTX Titan - Win7 Pro x64 - Intel i7-3930K - ASUS Rampage IV Formula-X79
coilbook
Wow Thanks!
After opening Octane viewport I get this after enabling coherent mode everything freezes up like in that video i sent with this message
Failed to load preferences from "C:\Users\.....\preferences_v2"
image 6 doesn't match image 0 for render pass 'Beauty'
coilbook
Hi Karba
The thing above only happens when network render is enabled and that's when octane viewport freezes
Karba
coilbook wrote:Wow Thanks!
have you updated slaves version?
coilbook
yes
both slaves have 2.11
and main pc has only 3ds max 2.11 since 2.11 is not installable version yet
basically when i open octane window let it render to the max samples i set lets say 1000 then if i do anything like adjust focus, disable coherent everything freezes but only with network enabled
Karba
coilbook wrote:yes
could you send me a simple scene where I can reproduce the issue?
[email protected]
coilbook
seems like with coherent mode i get this after 1 frame of animation render with network enabled
slave ..... (7) lost 1.0 samples
Thank you
Karba
coilbook wrote:seems like with coherent mode i get this after 1 frame of animation render with network enabled
Thank you
May I have a scene?
coilbook
I will tomorrow it is 300mb in size maybe i can email using google drive
I noticed it is ok now
the reason maybe
i had two frames 4000 and frame 4001 rendered with 2.06 as png sequence
other 2 with coherent mode on 4002 and 4003 frames
and other 2 with 2.11 that's when i disabled the coherent mode and render would just stop with that error message
All those renders when to one folder I guess octane was comparing new image to my old image rendered in 2.06?
Because when i created a new folder and started rendering from scratch with 2.11 only, starting at frame 4000 it works ok
lol strange
Locked
