What are you trying to render? Can you post a screenshot showing the problem?ura wrote:does not show the texture
it worked before, now the texture is only visible in the preview
Roeland
We can fix the first issue, the other is is more difficult; for now if you want to use normal maps you are limited to plain RGB image nodes.matej wrote:Normalmapping still doesn't work, if:
- the nmap texture is provided through the texture input pin of the macro material
- two nmap textures are mixed together with a texture mix node
