Animate value with Lua scripted graph
Forum for OctaneRender Lua scripting examples, discussion and support.
p3taoctane
is there a visibility node that could be controlled by this animation script by any chance?
I have an ABC node going in and I want to make it invisible until a certain time ... besides opacity node in the shaders that go into it... is there a way to do that?
Peter
Hi Peter,
you need an Object Layer node connected with all the .abc related pins. In this way you can animate the General Visibility with the Animated Value scripted graph:
p3taoctane
Thanks as always Bepe
what are those two nodes you have that the object layer is going into ?
When I export an ABC I do not have the ability to put an object layer in
calus
p3taoctane wrote: When I export an ABC I do not have the ability to put an object layer in
If you export as ORBX (with embeded Alembic option) from the Octane for Maya plugin, it's possible to export object layers,
but as usual with the Maya plugin it's very clunky :
- set the Octane Bake ID from 0 to 1 for every shape you need an object layer for.
Anyway you could also just animate the Octane Visibilty parameter directly in Maya before exporting then you don't need to script the animation in Octane SA.
Pascal ANDRE
p3taoctane
Thanks Calus
Yes you are right very clunky I will give your suggestions a try.
azims
Bepeg,
Can I use this script to set different camera positions/ key frames and render an animation? If yes then how do I go about it.
yes, you can use it to move a camera from A to B, and eventually go back to A, with the Ping-Pong option active.
You need to use two AnimatefFloatSG, one for the Position Value, and the other for the Target value,, and copy paste the start and end values from two camera nodes. Please, have a look at this example (sorry for the basic quality):
hairtest-anisg.orbx.zip
(17.22 KiB) Downloaded 948 times
ciao Beppe
azims
Beppe,
Thank you for the scipt. I have a follow up question. Can I feed more than one start & end values to mimic multiple key frames?
unfortunately it is not possible, as said, only from A to B, or A to B to A, sorry :(
ciao Beppe
azims
Beppe,
No issues. Do you know/ recommend any add on or plug in which could add this functionality to Octane? I am importing mesh geometry from two different modelling applications. Essentially Octane Standalone is my studio where I integrate assets for the whole scene and render. This works perfectly for still images but I need a solution to render walk-through animations.
Thank you,
Return to “Lua Scripting”
