OctaneRender® 1.025 beta2.58 test release [obsolete]
Refracty
Refracty wrote:Octane fails to start and hangs.
only a fire wall issue - I will go into testing now :)
Magog
It's impossible to use this release, Octane crash costantly! :cry:
i7 970 3.3 GHz | 12Gb Ram | GTx550Ti for display + Gainward GTX580 1.5 Gb and Zotac 590 3 Gb for Octane | Win7 x64 __ Softimage 2011.5
Zay
Magog wrote:It's impossible to use this release, Octane crash costantly! :cry:
Crashes constantly for me too...back to v2.57.
Win 11 Pro | i5 12600K | 32GB ram | 2x GTX 1080Ti + 3080Ti - studio driver 560.94| Modo/Blender/ZBrush/Daz/Poser
matej
Have you guys downloaded the updated version from today? The links on the first page were updated with a patched version.
If yes, then describe the situations when it crashes. Just saying it's crashing is not very helpful.
cgmo.net
i've also a lot of crash in opening 257's scenes but no problems with old ones, probably is related to the new light sampling system :roll:
Magog
Matej You're right, but if I did not give specific feedback, it's because I can not find out the origin of the problem.
And yes, I downloaded the new upldate.
Octane crashes without any logical sense. Not a problem on a specific material / node or parameter, since it crashes if I change the opacity for example, if I change any node, if I change a value of environment, if I copy a node, if I import a node if I change random value in the kernel ..
I have also tried to reload the scene without export from XSI, but it is always the same.
Same question with new or old scene.
I hope to be helped.
matej
^ That sounds very strange.
Just for the record; I've been working with it today for about two hours, but experienced no problems at all. It feels stable like 257.
cgmo.net
Magog
Maybe I understood what is the problem, I hope. I was reminded just now .. I Using the toolkit 4.2 of CUDA. It is the only reason, I can't see other solutions. Tomorrow I'll try to reinstall it.
roeland
katerlake wrote:With this release, i start Octane render, import with an mesh-node an *.obj and octane will not render.
But if i start C4D and use the exporter, octane start render. I´m confused. :o
By the way, this release is an living sign of octane, but in my opinion it is better on the final version of the standalone to work as a plugin solutions to all.
Can you start the render by right-clicking the mesh node and selecting "Render"? If so you have disabled automatic previewing of mesh nodes. Otherwise, is it a problem with all the OBJ files you try to load?
Roeland
grimm
Hi Roeland,
Thanks for the new release. I'm just posting the bugs as I find them.
Very tiny bug, the tool tip on the subsampling icons is the same on the 4x4 icon as the 2x2 icon.
Jason
