OctaneRender® 1.025 beta2.58 test release [obsolete]
roeland
Hello,
The OctaneRender® Team is pleased to announce the beta 2.58 test release.
Changes introduced in 2.58
Quick material previews.
It is possible to enable quick previews of materials and textures inside the node
inspector. These will be rendered without interrupting the main render, and will
update automatically when the material or texture is changed. The scale of the
material can be updated as well.
There is a choice of a preview on a sphere and a flat 2D preview. The scale of
the object shown is customizable, and users can choose default settings in the
settings dialog.
New light source sampling.
In the new release light sources are sampled by power instead of by area.
This should work well in a wider range of scenes than our old area based sampling,
reducing the need to manually tweak the sample_rate parameter of the emitter. If
you have a scene where you have tweaked the sample_rates, you will have to do this
tweaking again for the new system.
Further tweaks to the node graph editor.
  • The node graph editor supports copy/paste.
  • Add application-wide shortcuts for cut, copy, paste and delete, and put these in the application menu.
  • Add dropping of macro and mesh files on the nodegraph editor.
  • Node pin connections are saved when saving multiple nodes.
Other features and bug fixes.
  • Implemented copying the rendered image to the clipboard.
  • Added scrollbars to the render view component when the image doesn't fit the display area.
  • Maximum Z-depth is a separate slider on the deep_image_channel kernel node.
  • Added viewing of the UV mapping to the deep_image_channel kernel node.
  • Zooming in and out the rendered image is usable with smooth scrolling devices like trackpads.
  • Menu structure on Mac OS more in line with conventions, multi-material pick uses
    the standard context menu bindings.
  • Right mouse button works inside the render viewport on Mac OS.
  • Color picker preference is properly saved, and is selected with a combo box.
  • Remove the Update button in the resolution settings component, changes to the input fields are applied immediately.
  • Added aspect ratio lock to the resolution settings component.
  • Linear/logarithmic keeps working after changing float node value.
  • Fixed broken loading of RGBA images into a float node.
  • Fixed possible stability issue when the connection to OctaneLive drops out.
Known issues
  • On Linux the PMC kernel doesn't work on pre-Fermi GPUs (i.e compute model 1.1 - 1.3) - we couldn't find the problem yet, which seems to be a compiler bug.
Download here:
Due to this being a Test Release, we are only providing zip/tgz archives, no installers.
Windows:
ZIP archives:
- 64-bit32-bit
MacOS X:
- 32-bit
Linux:
- 64-bit
Driver Requirements: This release was built with CUDA 4.0, which means that you need a recent enough NVidia driver (http://www.nvidia.com/page/drivers.html).
For Linux and Mac OS you also need to install the CUDA Toolkit 4.0 (http://developer.nvidia.com/cuda-toolkit-40).
For Mac OS you also need the latest CUDA 4.0 driver (http://www.nvidia.com/object/mac-driver-archive.html).
Yours,
The OctaneRender® Team.
smicha
Fantastic work! Thank You!!!
Magog
Wonderful work! Tnx a lot!
i7 970 3.3 GHz | 12Gb Ram | GTx550Ti for display + Gainward GTX580 1.5 Gb and Zotac 590 3 Gb for Octane | Win7 x64 __ Softimage 2011.5
Daniel79
For instance, perhaps we should wait the v3??
Honestly I expected more after all this time.
have a good time...bye
SORRY, MY ENGLISH IS BAD!
2 Xeon quad core E5440_8gb Ram_Nvidia GeForce 2GTX 780ti 3Gb/Nvidia Quadro K2000_Win10 64bit_Octane 3.02_Rhinoceros3D
Elvissuperstar007
tweaking again for the new system. ??????
where it is?
matej
Very nice list of usability updates (copypaste, YES!!1!1!!)
Unfortunately for me Octane crashes each time I enter a macro node (or any container, like for ex. the "preview imager") and try to move around some node in there. Just creating a macro on an empty scene, entering and moving the "output" node crashes Octane. :( (illegal instruction, yada yada...)
Moving & copy/pasting things outside macro nodes (on the top pane) works ok.
cgmo.net
Elvissuperstar007
obscure release! the sun passes through the glass?
Pacific88
matej wrote:Very nice list of usability updates (copypaste, YES!!1!1!!)
absolutely same trouble.
Magog
Yep, constant crash with Macros node, and often even after the export the scene to Octane.
To solved, I have to save, open Octane and retrieve the file ocs ..
matej
btw, if would be cool if the pasted node would appear under the current cursor location, not exactly on top of the copied node.
cgmo.net
